Old 08-05-2010, 11:48 PM   #1
05crewcab
05crewcab's Avatar
incremental squeaking
Hi guys,
probably a stupid question here...
i am getting a squeak from one of the front wheels, but only when i turn the wheels to the left. If I apply the breaks it goes away, but i don't think it is a wear indicator because wouldn't it squeak regardless of the direction I turn the wheels? I am leaning towards a wheel bearing, but don't really know how to diagnose it.
Any thoughts?
1971 C-20 350/350
05crewcab is offline   Reply With Quote
Old 08-05-2010, 11:50 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: incremental squeaking
could a wheel bearing cause alot of break dust?
mines doing the same thing actually...but my brakes are hangin' too, im hopign its a prop. vavle because thats the only old thing on the brake stuff now..
John
1999 Toyota Tacoma 4x4
Old 08-06-2010, 11:17 PM   #3
hayhauler71
hayhauler71's Avatar
Make sure your pads are tight in the calipers and the rattle clips are holding good to the piston. Also put some synthetic brake lube on the back sides of the pads to prevent vibration the leading cause of brake noise.
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 08-07-2010, 12:15 AM   #4
05crewcab
05crewcab's Avatar
hey hayhauler, why do you think mine only makes noise while turning to the left? I feel like brakes would make noise all the time...
1971 C-20 350/350
Old 08-07-2010, 05:50 AM   #5
cdowns
cdowns's Avatar
i'd put it up on jack stands with the wheels off and spend the weekend inspecting things and greasing up moving parts and looking for worn components
Old 08-07-2010, 03:31 PM   #6
Notrodder
I'm guessing that if you're unsure of the state of your wheelbearings, you're overdue to pack them. While you're at it, take cdowns advice. I think I'll do the same.
Notrodder is offline   Reply With Quote
Old 08-07-2010, 08:29 PM   #7
69 longhorn
You will get a laugh out of this one..... I had an old Merc do that to me, & had that front wheel off a half dozen times. It would only squeak turning 1 direction, the pads & rotors looked good. After a little harder look, I found a small pc of gravel stuck tween the rotor & the splash guard! You might also check the wheel bearings(as already mentioned). crazyAL
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 08-08-2010, 01:50 AM   #8
05crewcab
05crewcab's Avatar
you know, it could be as simple as a chunk of something stuck somewhere. I haven't had a chance to inspect anything since posting, but will let you know if I am fighting gravel
I'll check the wheel bearings too but I am not really sure what I am looking for...
1971 C-20 350/350
Old 08-08-2010, 02:11 AM   #9
Notrodder
A service manual will tell you exactly how to do it. They actually need to be packed fairly often.
Old 08-08-2010, 05:26 AM   #10
cdowns
cdowns's Avatar
shock mounts cause squeaks sometimes// the top muont studs loosen up and enlong the mounting holes// just grab hold of shock and wiggle
have you ever greased the balljoints or tierods or any of the aframe bushings?
have you checked the brake pads?to see if there"s anything there like brake pad material?
service manuals are great tools
Old 08-08-2010, 05:04 PM   #11
05crewcab
05crewcab's Avatar
well, got a few minutes to pull the front wheels....it's the brake pad wear indicator on the left wheel...so it looks like brake pads are in my future.
The wheelbearings seem tight and have plenty of grease, so they must have been repacked before I bought the truck in March.
Since I will be doing pads, i might as well get the rotors turned, and at that point I will repack the wheelbearings again to keep the service interval.
Also, I noticed my upper balljoint on the left side is riveted not bolted, so it must be the original?? Might have balljoints in my future too...
...and, the service manual is in the mail
Thanks guys
1971 C-20 350/350
Old 08-09-2010, 07:35 AM   #12
mrein3
mrein3's Avatar
Thanks guys
I've done a million of the upper, riveted in ball joints. The easiest way for me is to take a flap wheel in the grinder and make the head of the rivet go away. Then put a punch in your air hammer. A couple of blows with that and the rivet is gone.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
