08-05-2010, 08:24 PM | #1 |
Graduation Present, One Bad Mudder
Hey fellas, I got a 65 Longbed with a 327 4 speed. I got it from my bro for my graduation present. Its pretty unique, 2wd with a lift . Anyways, aside from the previous owners shotty craftsmenship I think I've got alot to work with.
I'm wanting to put mid 70s-80s axles under it with 4:11 gears, probably a little bit lower, Married transfer case. 6 inch lift or higher, and run with 38s. Engine wise, I'm planning on building a 377, with hopefully 425hp at 5 grand or so. Really haven't thought this part out yet, I'll probably throw in this 305 I got here at the shop as a mule motor. Any of you guys got any gearing ratios yall think are good, axles to look out for? I'm more of a hot rodder than a mudder. Well, I haven't went mudding in any chevys yet, I drive my buddies 78' Bronco on 36s, while he drives his Samurai on 38s |
08-05-2010, 10:04 PM | #2 |
Grease Monkey
Re: Graduation Present, One Bad Mudder
I'd rebuild the 327. I'd suggest a 205 tcase, dana 44 front, 14 bolt rear. Talk to Kurt at DIY4X to help with the front axle setup. For gears it all depend on your transmission. Looks like a good foundation for a build. Good Luck
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
08-06-2010, 11:14 AM | #3 |
Thanks man, what are you runnin on your truck
