Re: Narrowed Rear End?
Also look at Dutchman for axles
How much narrower are you considering?
Sometimes it's cheaper to find a 'car' housing that's already the right width which keeps things 'stock' vs. custom/narrowed. Seems like alot of things w/that ID attached get expensive in a hurry.
![]() Join Date: Nov 2009
Thanks for the replies guys. I am thinking of running 33x21.50x15's on 15x15 rims. I will have to narrow the frame as well. If i buy new axles and have them drilled for 5 lug what drums will fit my original rear end?
60-66 Nut
What I would do is change the backing plates to the '76-'87(?) style which use the wider 2 1/2" shoes. Then you use the same year of drums.
I'm not sure just how wide you can go with the trailing arm suspension....12-14"? You might checkout the 'Racing and High Performance' section, there are several guys over there running trailing arms and wide hides.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-09-2010 at 01:11 AM. |
#5 | |
