08-09-2010, 12:13 AM | #1 |
FIXED HANDLING PROBLEM-Question on Tires and handling? "Circuit Rider"
I have done a lot of searching w/o finding answer an answer. The Circuit Rider has Goodyear 285/60r16 tires on all four corner. After driving about 200 miles the last few days the truck just doesnt seem to handle right. These tires were on the Torq Thrust II's when I bought them back in 2008 (they were used then) so the questions is...what might be the possible cause of this? It has a 2/4" drop with new shocks and fully rebuilt front end.
Would new tires improve this situation? All I know is when I get up to 55-60mph I am not comfortable with the handling of my truck. It almost feel like it wants to wonder left to right....not a lot but a little but enough that I do not feel comfortable at highway speeds. Ideas and thoughts??? When I take the truck in for a final tune up next month I want to have some ideas as to what to look for. Thanks in advance.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 08-13-2010 at 11:25 AM. |
08-09-2010, 12:32 AM | #2 |
Factory Strippers Rule!
Re: Question on Tires and handling?
Front sway bar. Without it, you will get seasick even on a straight highway.
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
08-09-2010, 12:38 AM | #3 |
If you're not comfortable going in a straight line at 55-60mph you have a pretty big suspension issue. Did you get an alignment when you rebuilt it the front end? If not you need one.
Are the tires in good shape? If they're worn, especially unevenly worn, then new tires will help. I have a 71 1/2 ton 2.5"x4" drop with 27" od tires on 18's and it runs straight as an arrow. My 72 Jimmy, stock height is almost as straight but it has 32's on 15's so I don't expect to be as docile as my truck. |
08-09-2010, 12:43 AM | #4 | |
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
08-09-2010, 01:08 AM | #5 | |
I'll go out tomorrow and see if my truck came with one. It is my understanding that some trucks came with front sway bars and some did not. Thanks
08-09-2010, 06:28 AM | #6 |
did you use new balljoints tierod ends idler arm pitman arm trailing arm bushings trackbar bushingsetc// theres a big difference in the way an up to date suspension handles compared to a 40year old wornout one handles the road
08-09-2010, 08:06 AM | #7 |
It has an ECE Front Sway Bar set up and the front end is all brand new as this has just come off a frame off. I am thinking alignment as it does pulll to the right and maybe new tires are in order. The tread looks good but there can only be so many reasons for handling issues.
08-09-2010, 08:18 AM | #8 |
Re: Question on Tires and handling? "Circuit Rider"
I'm curious if anybody knows what the best setting for camber, caster, and toe setting for my truck (1970-- 2/4" drop) should be? Mostly country driving. Tire size: Goodyear 285/60r16"
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 08-09-2010 at 08:25 AM. |
08-09-2010, 09:44 AM | #9 |
Forgot to mention, check the brakes and wheel bearings. Maybe you're getting some binding/drag on the right side.
08-09-2010, 10:00 AM | #10 |
Restoration Virgin!
check w/ 'cparman'.....I've seen him post some alignment stuff a while back.....Also, I called the local hot rod shops around me when i need to get an alignment....they sent me to an old school cat that worked his magic AND told some really good stories as I watched him!!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
08-09-2010, 10:37 AM | #11 | |
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 08-09-2010 at 10:39 AM. |
08-09-2010, 12:28 PM | #12 | |
I stopped in the local body shop who is heavy into street rods...he suggested a guy who has been in the Alignment business for over 35 years and does all the local stret rods. So tat will be my next step. Again thanks gcburdic ... good recommendation.
08-09-2010, 01:31 PM | #13 |
Chevy Truck Addict
One thing you may want to consider is the width of the front tires. A 285 is pretty wide and one of the problems with wide tires is that they grab the grooves in the road. A narrower tire will tend to handle a lot better. Keep the wide tires on the back and run a 245 or something close to in on the front.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
08-09-2010, 03:07 PM | #14 | |
08-09-2010, 03:18 PM | #15 | |
08-09-2010, 04:06 PM | #16 | |
Restoration Virgin!
Usually works by cash only too Mine was $60
08-09-2010, 04:22 PM | #17 |
C-10 Club Member
Probably not the case but I have seen people mount directional tires the wrong way. Adds for weird handling, noise and some very hot tires.
1969 Short Fleet 350/SM465 4.5/6.5 ECE drop 20" Raceline Wheels 1998 2dr Tahoe 5/7 drop 20"/22" Coys-sold Build thread...http://67-72chevytrucks.com/vboard/s...d.php?t=401910 |
08-09-2010, 07:53 PM | #18 |
That's interesting in what you just said. I met with Mark and he has aligned cars & trucks for over 36 years. He has no computer equipment but he does have a good amount of tools that he uses. Full alignment is ... $45. Mark said the toe in setting could also be off. Oh yes... no credit cards. Cash or check. Mark said it should only take an hour so I should stay and watch and we can swap stories. His shop is only about five miles from my house. Life is good.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 08-10-2010 at 07:27 AM. |
08-09-2010, 08:50 PM | #19 |
Restoration Virgin!
Awesome!....Sounds just like the shop I went to....obviously, prices vary by region
OH....I forgot....the guy that did mine chewed tobacco....he had 3 different spit buckets....which he used every time he passed by one.....he probably hadn't emptied them in like 10 years!!!!
08-09-2010, 08:51 PM | #20 | |
My top tires of choice are Goodrich and Michelin...the Goodyears were on the TT II's that I bought used. It has been recommended that on the front I switch from 16x8 to a 16x7 size rim. Then I could re-install the 2" drop springs w/o rubbbing/hitting issues. I am now going through the fine tuning stage of the restoration. Thanks all for your input.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 08-09-2010 at 08:51 PM. |
08-09-2010, 09:29 PM | #21 | |
08-09-2010, 09:57 PM | #22 |
Cruzin
is your center link on backwards? that was my problem after we rebuilt the front end it wanderd left to right
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
08-09-2010, 10:08 PM | #23 |
I am on the road so I can check it out when I get home...Thanks for the idea.
08-10-2010, 07:49 AM | #24 |
its all about the +6 inches
try filling the tires to max PSI.
Too many ppl go by the old 32PSI rule, then they get new tires that are designed to hold 45 or more PSI. |
08-10-2010, 07:56 AM | #25 | |
Another good point. I am making a check list to follow up on. When I get home I'll check this out. Thanks.
