Help Please with Dually Rims
I recently acquired a 1969 C30 dually Chevy truck. It lived most of its life resting in a field in Riverside. The tires are rotten and I am trying to put modern tires on it. But my local independent tire shop won't touch the old rims with lock rings (these aren't the same as "split rims" are they?).
So I found some Ford rims and tires for a good price on CraigsList thinking I could work with them. ![]() Today I did some better measurements and here's what I found. The hub holes on the Ford are 124 mm. The hub holes on the Chevy are 115.9 mm. The lug holes on the Ford vary from 17.1 to 17.28 mm. The lug holes on the Chevy are a sloppy 1/2 inch at around 13.3 mm. I know I have to fit the wheels in a hub centric fashion. But what I can't figure out is whether I will be time and money ahead to just buy some 16 inch Chevy rims. And if so, can anybody tell me what years actually used the 4 9/16" (115.9 mm) hubs. Try as I might, I just can't seem to find out that information. And, of course, I don't want to use the 16.5" rims. I really want to stay with 16" wheels. Thanks in advance for any help to this newbie. |
Re: Help Please with Dually Rims
I have a 67 C30, and it too came with the split rims. Your truck indeed does have split rims.
I bought rims from a 75 Chevy dually. If I remember correctly you should be able to use any dually rims from a 73-87 (and possibly newer?) GM. The main difference is that they use 9/16" lugs instead of the 1/2" lugs. I am swapping over disc brakes from a 75 one ton so my front will have 9/16" lugs, so I will only have to convert the rear lugs to 9/16".
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
So, you're telling me that all the '73-'87 trucks have the 4 9/16" (115.9 mm) hubs?
I know that at some point they changed to 4 5/8" hubs. Just don't know when???? |
![]() Join Date: Sep 2009
Part of the problem is that you are measuring in metric. We only have three metric tools in our shop... a hammer, a hack saw and a cresent wrench. Ha
You can shear a sheep every year, but you can only skin it once The person dealing with facts is never at the mercy of the person dealing with theory 1972 Cheyenne Super 402 400 A/c bucket seat tilt custom camper Longhorn 1975 Silverado 454 Crew cab camper special dually |
Yeah. I know. Just tryin' to be modern!
It's just that there are SO many variants of the 8 on 6.5" dually rims. And this is preventing me from getting this old truck on the road. Frustrating. |
GM has always been really good about interchanging parts. Like 71swb4x4 says, Next jen. wheels will fit. If your not worried about keepin it stock, There are alot of parts that can be swaped if you know what your look for that will make your life alot easier.
Find a GOOD tire guy and some wrecking yard guys that will work with you. I,m in the Central Valley and have a hand full of them. If you where closer i'd show you around. This is the best place I have found so far for good info. Good luck. |
If guys can fit PYO's (the polished alum wheels from the new trucks) I can only assume that the newer dually wheels will fit too.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
You're absolutely right. I will have to have Hub Centric Adapter Rings made up specifically to fit. Inside diameter has to be the same as my hubs and outside diameter has to be the same as the wheels I am using. And since the Fords are common, it shouldn't be a bad way to go.
But, if I knew I could hold out for some Chevy rims that would fit my hubs precisely, I might do that. But I would have to know which years have the 4 9/16 hub diameter. |
*** That's interesting ***
I have the later (73+) Chevy rim style on my '69 C30. And the previous owner already did a later-year front disc brake conversion, so it's nice having one spare tire that will fit on the front or back. Keep that in mind when going through these gyrations of using adapters. If you plan on doing a disc conversion, then I'd go with the later Chevy dually rims so you can run one spare that fits all. I can measure the lugs if you want. But you may be able to just pull up specs on various 73+ C30 front rotors (online, ie: NAPA) and see what those numbers are.
Tom ![]() Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... Last edited by storm9c1; 08-03-2010 at 04:09 PM. |
you know,up to a 1991 R (old body) C/30 2wd front susp. crossmamber will bolt right up to the 69 frame with only 2 minor mods..you have to drill 2 holes. thats it..Then you have the saftey of front disc brakes too.
I just walked out to my dump truck and visually the wheels off the 75 look like they are the same hub size as the hubs on the dump truck. They are seated very nicely.
"brand new second-hand"
ToddC-I was in Pick-a-part today on 6th and waterman. They have a c-30 flat bed truck in there with dual wheels-I didn't look that close, but maybe it's something you can use-it still had the front drums etc.....good luck
Steve 69 3/4t custom camper tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c 67 Camaro 96 Impala ss-sold 04 hybrid Honda-saving gas for the blue truck!:b69: |
sorry forgot-its a 68 or 69 I believe.............
Thanks guys. Options are opening up!
#15 |
landarts
![]() Join Date: May 2005
I know where a 68 c30 with new tires on it that the guy is parting out, would you like me to look into it for you?
Jim |
#16 |
#17 |
Just to kill this thread. I decided to stay with my original rims. They AREN'T illegal to run in California. I just had to go to a truck tire place to get the newer tires mounted on the old rims. Cost a fortune since they charge a higher rate for dismounting and remounting on the split rims. Plus I had to buy 6 new tubes. Yup, the split rims don't work with tubeless tires unless you add tubes. But, the truck is finally on its own tires and I won't have to worry about the old rotten bias ply tires.
