Old 08-05-2010, 01:34 AM   #1
old_1966_GMC
66 305E upgrade HELP!
i need to know whats a real good performance stater, fuel pump,altanator,pistons, camshaft and any other parts i may of missed to put on my 305E engine its a 4 speed.also looking for some good working 66 gmc 351M heads to add on
1966 C1500 3/4 ton longbed fleetside sbw
old_1966_GMC is offline   Reply With Quote
Old 08-05-2010, 09:48 AM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: 66 305E upgrade HELP!
unfortunately, there really aren't many other options for getting performance out of your 305. Keep in mind these are truck motors that don't spin very high because of heavy crankshafts and a 60 degree design. The "m" heads, different carbs, exhaust and distributor are about all you can do without having custom made parts or some serious machine work. check out
www.thunderv12.com. they did some crazy things but you'll notice the price reflects that as well.
My advice is enjoy it for what it is unless you want to spend big money.
Old 08-05-2010, 12:13 PM   #3
old_1966_GMC
so will the remans from autozone do any good like the starter,fuel pump,and the altanater these are non performance just reman replacement parts that pricr arent that bad
Old 08-06-2010, 12:26 AM   #4
Corts60
Just here to tinker
Corts60's Avatar
Sure they are fine to replace but why fix it if it isn't broke? It wouldn't hurt to buy them and have them around though...who knows how much longer the V-6 stuff is going to be available. There is basically no desire for them by most car enthusiasts. Just a few of us crazy guys that gotta be different.
Old 08-06-2010, 12:35 AM   #5
skoffice
skoffice's Avatar
I'd love to be fortunate enough to be different like you guys. I think those engines are just plain neat. And I agree with Corts60, those parts would be very expensive to make from scratch, plus the design of the engine just wasn't made for the performance enthusiast. They were all about torque and lasting as long as they could. If you want more out of it you could try to locate one of the 400+ CI model V-6's. Those have loads of torque.
1964 C10 Shortened Shortbed Cammed LQ9 P&P
1967 C10 Trophy Truck BB 438 (soon to be worked on again)
skoffice is offline   Reply With Quote
Old 08-06-2010, 01:11 AM   #6
old_1966_GMC
i think im just ganna stay withe the 305 after all the info i got from u guys and research i've been doing but tend to wanna swap carbs withe holley 500 but i just cant find a 2bbl intake manifold no where and sense im a register user i cant post nothin on the wtb threads i will be adding some pic of the old 305 i got on 66 gmc when i get home
the stock single carb takes a a min to get it going
Old 08-06-2010, 01:44 AM   #7
skoffice
skoffice's Avatar
That's going to be tough to find I bet, but that should open up some more power for you right there if you do find one. Its a shot in the dark but check local scrap yards. I have seen a couple of the V-6's at pick n pull before. I know what you mean, I need to get some funds together and sign up as well!
Old 08-06-2010, 01:50 AM   #8
old_1966_GMC
if any knows where i can find one please let know
Old 08-06-2010, 03:17 AM   #9
old_1966_GMC
reasons to grabbing replacement parts was to make this thing look good again and make it run like it did when it first came out the factory
Old 08-06-2010, 08:24 AM   #10
duallyjams
duallyjams's Avatar
check out the forum on here http://www.6066gmcguy.org/ do search these guys have reground cams, replaced piston,balanced the rotating assembly, made a 4 barrel intake out of a 2 barrel M intake so you can do upgrades.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 08-06-2010, 09:07 AM   #11
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
I have a blown up 351 for parts on the parts board, take a look and see if it has anything you need...
Old 08-06-2010, 01:13 PM   #12
creep
Registered Loser
creep's Avatar
If your motor is a 66 you shouldn't need an intake manifold, just the $20 adapter. Does your intake have 3 or 4 carb studs?
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 08-06-2010, 01:29 PM   #13
creep
Registered Loser
creep's Avatar
If it helps, you can see some pics of my swap on page 2 here;
http://67-72chevytrucks.com/vboard/s...d.php?t=354432
Old 08-06-2010, 02:17 PM   #14
old_1966_GMC
well here are some pic of my 305 i have in the gmc. Thank for the help creep i found out i do have to rigth manifold to do the swap.
Old 08-06-2010, 02:35 PM   #15
70BLAZERX2
check these out and also look in to offenhauser they do have some very odd stuff.
70BLAZERX2 is offline   Reply With Quote
Old 08-06-2010, 03:18 PM   #16
old_1966_GMC
im think of stripping the paint off and go with cast iron on the block and some type of black on some of the parts.Just always like the gray and black looks on a engine
Old 08-06-2010, 05:43 PM   #17
welsh kev
welsh kev's Avatar
Once you've junked that original carb and fitted the Holley, you'll be surprised how much better the motor pulls. Some advocate fitting a Pertronix ignition system, but mine still runs stock ignition and she's on the button every time.
63 GMC fleetside, 305 V6; over-built, over thirsty and over here!
welsh kev is offline   Reply With Quote
Old 08-07-2010, 12:51 AM   #18
old_1966_GMC
what about hei distirbutor has and anybody had any luck with them?
Old 08-08-2010, 08:24 AM   #19
duallyjams
duallyjams's Avatar
I did some research on the HEI on ebay and the reviews were not to good.I use and most others use pretronix conversion.
James
IG duallyjams
Old 08-08-2010, 09:44 AM   #20
C-10 simplex
i think these engines are available from Jasper's at about $4500. Just letting everyone know.
Not a bad price when you consider it.
C-10 simplex is offline   Reply With Quote
Old 08-08-2010, 01:30 PM   #21
old_1966_GMC
whatare good high engine paint from a auto parts store
Old 08-09-2010, 04:49 PM   #22
skoffice
skoffice's Avatar
I'm not too sure where you can get it but we always use Aerovoe engine paint at the shop I used to be at and it is GREAT paint. I don't recommend Duplicolor. Try to find a set of plaid valve covers maybe, that would look cool with black and gray.
Old 08-09-2010, 06:20 PM   #23
old_1966_GMC
i look into the plaid valve cover,what are the factory color for the 305 did they al had th same color or each truck had it own color like my truck facory color was red but i dont know if the blue is oirginal to the engine
Old 08-10-2010, 12:42 PM   #24
skoffice
skoffice's Avatar
I'm no expert but I think they all had Corporate blue..
