Old 08-10-2010, 02:52 PM   #1
Heater63
Heater63's Avatar
Hidden Hitch on 60-66?
I am wanting to eliminate the rear most crossmember on my '63 Short Step to make more room for a fuel tank. Is it possible/good to use a trailer hitch to replace that crossmember? It seems redundant to leave it if you have a good solid hitch.
I like the idea of a hidden reciever, like you see on '67 and up. Have any of you seen one or done this on a 60-66? Built Custom made recievers??
CaptainFab?
292 + TKO500
Heater63 is offline   Reply With Quote
Old 08-10-2010, 02:57 PM   #2
nomrlz
nomrlz's Avatar
Re: Hidden Hitch on 60-66?
this is something i'll be lookin for when the truck becomes road ready as well
nomrlz is offline   Reply With Quote
Old 08-10-2010, 03:06 PM   #3
steverino66
Me3. Already planning to haul parts trailer for the next project.
steverino66 is offline   Reply With Quote
Old 08-10-2010, 05:52 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Were making a hitch the old way with 1/2" X 2 1/2" flatbar.
Using a Hidden Hitch as a rear frame brace would support the bottom but not the top from twisting. May I suggest if you go that route you put a flat bar across the top of the frame to prevent it from spreading. Perhaps cap the end of the frame to prevent twisting.
Hidden Hitch Link:
http://www.hiddenhitch.com/fitguides...+ft.+Bed&Go=Go
Reese Link
http://www.reeseprod.com/
Valley Link:
http://www.vtowing.com/ApplicationLookup.aspx
Curt Link:
http://www.curtmfg.com/index.cfm
