Old 08-09-2010, 03:31 PM   #1
vintage_car
swapping trans tree to floor shifter
I have a 235 with a 3 speed on tree...I bought a 216 that has a 3 speed floor shifter. Are these interchangeable? Are there do's/dont's on trans removal?
vintage_car is offline   Reply With Quote
Old 08-09-2010, 04:52 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: swapping trans tree to floor shifter
Are you asking if the trans is interchangeable or the shifter?
Old 08-09-2010, 05:40 PM   #3
vintage_car
well if I can just put the floor shifter on the trans I have, I'm sure that would save me lots of time, but if that isn't possible, are the trans interchangeable. I guess some could tell from my basic questions, I'm no pro to this, so any help/guidance would be very appreciated.
Old 08-09-2010, 08:01 PM   #4
raycow
What year are the transmissions? Are they both from a truck or is one a truck and the other a car? If you don't know, please post pics of both of them.
Ray
raycow is offline   Reply With Quote
Old 08-09-2010, 08:26 PM   #5
OrrieG
OrrieG's Avatar
all truck and car 3 speeds were column shift in these vintages, so is it an aftermarket type like Hurst or later model Saginaw or GM? If it's a car trans and shifter the lever will be too short and may need modified to miss the seat. I put a Hurst shifter in my 1st 57 TF in 69 and had to drive around hunched over to reach it.
Old 08-10-2010, 12:08 AM   #6
vintage_car
I know the engine/trans that has the floor shifter came out of a 1949 truck, my truck is a 1950 and is the column shifter
Old 08-10-2010, 10:47 AM   #7
raycow
You are good to go then. The truck 3 speed was externally unchanged 1948-54.
Ray
Old 08-10-2010, 11:27 AM   #8
vintage_car
so is there a way to just swap the floor shifter to my currently installed column shift transmission, or do I need to do a full trans swap?
Old 08-10-2010, 12:49 PM   #9
raycow
Assuming both trucks are stock, the transmissions should be the same. Just swap the shifter and the transmission arms.
Ray
Old 08-10-2010, 11:51 PM   #10
solidaxel
solidaxel's Avatar
If it is a factory floor shifter I would think it is a 4 speed transmission, no!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-11-2010, 02:22 AM   #11
bobinbc
bobinbc's Avatar
Can you post a picture of the trans with the floor shifter?
1957 Chevy black 1420 LBSS
1955 Chevy green 1300 SBSS
1956 GMC red SBSS Nov 2017 ToTM
https://www.facebook.com/groups/Cana...geChevyTrucks/
bobinbc is offline   Reply With Quote
Old 08-11-2010, 08:29 AM   #12
raycow
The last 3 speed with a factory floor shift was 47. The OP says he has a 49, so I am assuming it has an aftermarket floor shift conversion. Of course you know what happens to people who assume......
Ray
Old 08-11-2010, 11:41 AM   #13
vintage_car
I will post pics tonight...it is pretty grimmy.
