#226 | |||
Still Learning
Re: 86 Silverado Father and Son project
Thanks!
Thanks! |
#227 |
Still Learning
Update:
I purchased a pretty much complete interior from guy on Craigs. It is in really good shape. The carpet is new and the door panels, and seat are really nice. Unfortunately, there wasn't a dash pad. We will get some pictures as soon as we get it installed (just a pile of parts now). Also,I scored an electronic speedo cluster from RandyP. (thanks!)now I'm trying to make it work with the oem harness and it's not working out too good. For some reason GM changed the flex on the back and basically none of the gages work. |
#228 |
Slots go on anything!
Look at the wiring diagram on the Autozone website for a 91 Suburban. You will just have to move the wires in the connector around a little bit, but most of them will work. I ran a wire directly to the output on the PCM to the speedometer. Just use the end of one of the wires that you dont use and lengthen it to go to the PCM. The colors will correspond to the later pinout, they are just in different locations.
Here is the diagram: http://www.autozone.com/autozone/rep...00c1528008f3ce I know I printed these, and I also had the factory wiring diagram for my '79 (thanks, ebay!). I did get the connector and about 6" of wire when I got my cluster, so that made it a lot easier. I was looking over that diagram, and I don't see the VSS output wire in the schematic. I know there are some diagrams on www.73-87chevytrucks.com also. All of my stuff is in storage, so it will be a little bit before I could dig it out to see the notes I made.
1974 Jimmy- 5.3/4L80e/NP241 Last edited by Jonboy; 08-06-2010 at 09:28 AM. |
#229 |
Next project: 1970 K10
I got your PM, and I'm sending you an email with the pinouts for the electric cluster and some other info.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
#230 | |
Best bet, when in doubt, is to follow each circuit from the gauge to the connection and note what goes where.
#231 |
Getting Old; Going Broke
I should have cut the connector off when I yanked that cluster.
![]() I don't even remember how/where the VSS was attached on that thing. I just remember getting it out and going "wow, this is different" and buying it anyway.
Why is every used 350 sbc out of a corvette? There's only two things that excite a man, expensive toys and real expensive toys. VEGETARIAN: That's an old Indian word meaning "I don't hunt so good." When the going gets tough, switch to power tools. |
#232 |
There is a DRAC module that went under the radio originally in the truck. I am pretty sure the buffer is in the ECM, as I wired mine directly to the ECM without any trouble.
1974 Jimmy- 5.3/4L80e/NP241 |
#233 |
Still Learning
Did you use the brown wire A10 or B3? on yours
#234 |
I really don't remember. I did mine about 8 months ago, and the first cluster I had, the speedometer didn't work. I went back and rechecked everything, and it still didn't work. The odometer worked, but no speedo. The funny thing is, I swapped that cluster for one that the speedo worked, and the odometer did not. I figured that was the lesser of two evils. Mine also had an LT1 in it, so the PCM is different. I found the VSS output wire in the PCM, and wired it directly to that.
#235 | |
Still Learning
HERE is the diagram I used for the ecm.
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 08-07-2010 at 11:33 AM. |
#236 |
Still Learning
Well it has been a busy week. Got quite a bit done on the truck. We gutted the interior to prep it for paint and the new to us interior. Still working on the speedo issue.
here are the pics: Got all the interior removed: ![]() Lots of junky parts: ![]() Prepped the headliner for new material and used Elmers wood glue. We tried THIS but it just fell back down. I used the wood glue back in the day and it worked great so I went back with it. ![]() Turned out really good: ![]() Painted the interior: ![]() ![]()
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 08-08-2010 at 11:03 PM. |
#237 |
Nice!
#238 |
Still Learning
Thanks Joe!
I got everything but the dash installed on the inside, this is a lot more time consuming than it is taking it out. Also, I scored a nice rear bumper at Pull a Part today. Here are the pics: Headliner installed: ![]() Carpet, seat and everything else: ![]() Like the new door panels: ![]() ![]() New bumper: ![]() ![]() |
#239 |
Wow Mike!
Quite a transformation!! Nice score on the bumper, what did it cost from pull-a-part? I need to pick up a new front and rear bumper...
#240 | |
Still Learning
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 08-08-2010 at 10:54 PM. |
#241 |
![]() I love that place, as long as you can get to the good stuff before the jackasses tear everything up.
#242 |
Still Learning
You got that right! I think they had just added a few trucks this week. I saw some stuff out there I would love to have for other projects. I have got to this one done so I can move on to the 69. Just need to rework the dash or buy a cover. New windshield, tag, fix the a/c again, and few odds and ends.........hopefully, by thursday.
#243 |
Under Construction
Very nice progress Mike!, truck looks awesome, I know your son has a perma-smile
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 08-09-2010 at 07:54 AM. |
#244 |
One day...
![]() Join Date: Apr 2008
Very nice
#245 |
Truck looks jsut amazing Mike. You have to be proud of what you have accomplished so far, just a little bit more and on to the next one! and yes it needs to some down just a little bit more now.
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#246 |
Now what??
Truck looks great! Bet that boy of yours is excited!!
69 Long Fleet - Project 06 Ram 1ton Cummins 4x4-DD 01 Tahoe- wifes "The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi "A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell my, um, build ![]() ![]() ![]() |
#247 | ||
Still Learning
Thanks Scott! Quote:
Thanks! Yes, he is pretty pumped! ![]() |
#248 |
^^who I am^^ what I say>
Nice truck,now it looks like all it needs is a trip to the exhaust shop! can you give more detail about recovering the headliner? I want to cover mine with a confederate flag, but not too sure how.
70 chevy LWB 350/TH350 Barn find (AKA the 70) http://www.67-72chevytrucks.com/vboa...d.php?t=406364 East Tx Squares |
#249 | |
Still Learning
As far as the headliner goes. It's a pain in the tail but definetly doable. The main thing we had to do, get off all that nasty foam backing. You won't get anything to glue to that crap. You can scrape it off with a piece of cardboard or similar. The one in his truck is the fiberglass type. So the first night I put a liberal coating of the wood glue over the whole surface. Then let it dry overnight. This will seal the glass and give a good surface to glue to. next day we glued the headliner on and worked it down flat. Keep in mind to give it slack as you lay the material, so not to stretch it. It seems to pull away from the backer if it stretched. Then just cut out for light and visors with a razor. I used a soldering iron to burn holes for the screws. It takes a few hours but worth it. Not sure how much a new one cost but we spen about $15 in material and $6 on glue. Good luck!
Mike "69 Short Wide" My Project 86 Silverado Landen's Project Instagram: @mcbassin My Website C/10 Club Oklahoma Facebook Group Last edited by mcbassin; 08-12-2010 at 04:14 PM. |
#250 |
One day...
They are around $65 to get one covered, thats from Truman fabric off i-44.
I bought my stuff from them and got a roller from Lowes and as i sprayed it rolled it smooth, seems to be holding up through all this heat we have had here lately so i must have done something right ![]() |
