08-09-2010, 05:00 PM | #1 |
Trans Question.....
Will a 350 tranny bolt to an inline 6? or better yet.....i have a 5 speed (dont know what type of tranny) w/granny gear and want to convert to an automatic.....what trannys will work for me? Thanks!
No Grumbo Be Humbo Last edited by 808humbo1; 08-09-2010 at 05:08 PM. |
08-10-2010, 12:20 AM | #2 |
60-66 Nut
Re: Trans Question.....
Yes a TH350 will bolt up to an I6 engine as long as it's a 230,250, 0r 292. You will have to remove the bellhousing crossmember, change the flywheel for a flexplate, change to a different starter, add a transmission cooler, and shorten your driveshaft. I'm sure I've forgotten a thing or two, but that's the basics. So you have a 5 speed in your truck now? If so that isn't stock. What year is your truck?
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-10-2010 at 12:21 AM. |
08-10-2010, 10:45 AM | #3 |
It's Better With Nitro
Yes, as mentioned the 194 through 292 blocks have the same trans mount...the only thing to keep an eye out for on on the trans bellhousing is for the BOP (Buick, Olds, Pontiac) pattern that appears to have a large dip on the top that accommodates the two higher trans bolt locations of those blocks.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
08-10-2010, 01:55 PM | #4 |
wow....i thought it would be a simple bolt on process and shorten the drive shaft.....hahahaha......i have a 62 LB. and yeah, i have a 5 speed on the floor with granny 1st. i really want to convert to automatic so the wifey can drive. where can i find all those other parts i need?
No Grumbo Be Humbo Last edited by 808humbo1; 08-10-2010 at 01:58 PM. |
08-10-2010, 02:22 PM | #5 |
It would be easier just to teach her to row gears. Oh, wait. No, it
would be easier to swap transmissions. If she's like mine that is.
292 + TKO500 |
08-10-2010, 07:03 PM | #6 | |
Ray Last edited by raycow; 08-10-2010 at 07:27 PM. |
08-11-2010, 01:15 AM | #7 |
60-66 Nut
This is puzzling to me. If you have a 5 speed with a granny 1st gear, I'm wondering what engine you have. A 4 speed with a granny 1st would be the common trans.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-11-2010 at 01:15 AM. |
08-11-2010, 08:25 AM | #8 |
5 speeds were available on the big trucks going back at least into the 50s. Look for names like Clark, Fuller, and Spicer. These will bolt to a 235 using stock parts, so it is certainly possible to put one in a pickup. They are huge and heavy though, so it is hard to make a good case for doing the swap.
Ray |
08-11-2010, 03:23 PM | #9 |
where can i get an adapter plate from? are they easy to find? pricey? thanks. oh and how many screws should there be for it to be a 235?
No Grumbo Be Humbo Last edited by 808humbo1; 08-11-2010 at 03:24 PM. |
08-11-2010, 04:16 PM | #10 | |
http://www.stoveboltengineco.com/aca...?productid=168 350 bux plus the cost of a new starter. A 54 or later 235 will have 4 screws around the edge of the valve cover. Earlier engines have 2 studs going through the center. Ray Last edited by raycow; 08-11-2010 at 04:26 PM. |
