break problems
so i replaced allot of my break parts on my 78 c10 and i having some issues with the rear brakes, they bleed but i get no movement out of the shoes. i replaced the brake cylinders, shoes and got the drums cut. im thinking the proportional valve is bad any thoughts guys or has anyone had the same problem
![]() Join Date: Jul 2008
Re: break problems
I would replace all the rubber lines front and back and that should solve your problem!They are bad to dry and not work proper and its not really understandable .I promise you will see the difference.bleed the heck out of it through the boxes and wash them out so nothing is in the way. Just pm me if you got Qs
Built chevy tuff! ![]() |
Re: break problems
thanks awesome ill give it a go and see what happens
Re: break problems
sounds like prop valve to me BUT its still a good idea to replace rubber lines.
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks.. |
