slip shaft driveline?
does anybody use a slip shaft driveline? i was told it was a must for lowered trucks... its 200 bucks plus carrier bearing.
anybody have one? where did you get it? like it?
70 longbed 496/th400/Ford 9" |
Fabricate till you "puke"
Slip yolk in the middle? Stock with a 3/4 ton truck.....yes i like it, havent broken the driveline in the last 10 or so yrs...ate a few U joint tho! BB olds was a powerhouse
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
its all about the +6 inches
heh heh heh Us longhorn owners are lucky on this one. I never had a problem out of the one on the old blue longhorn, however, the one ton sat long enough that the two halves froze together that it took 2 guys 3 hrs and a cutting torch to get the 2 pieces apart.
The lesson for all on that...if there is a zerk fitting...stuff it with grease. |
reason i ask is because http://www.classicperform.com/6092chevtrk.htm
they have one for sale and they say it is a must for lowered trucks. longhorns are cool trucks... i saw a 73-87 that had longhorn on the side right behind the cab on a little thing he had behind the cab... i dont think it was a longhorn... lol... but ive seen yalls trucks. they are cool.
