Old 08-12-2010, 10:40 PM   #1
ed70
is very serious
ed70's Avatar
STL craigslist
http://stlouis.craigslist.org/cto/1841651910.html
1967 C-10 2wd fleetside LB 350 4spd (dads) - sold
1970 C-10 2wd fleetside LB 307 700r4 - sold
1969 C-10 2wd fleetside LB 327 3spd - sold
1969 C-10 2wd fleetside LB 350 th350 - sold
1967 C-10 2wd fleetside LB 250 th400 -project in progress
Chevrolet=one who is dignified enough to expect every occasion is a special one and sees it fit to wear a bow tie... may others come under dressed.
ed70 is offline   Reply With Quote
Old 08-13-2010, 04:00 PM   #2
stsalvage
Scrapper 1
stsalvage's Avatar
Re: STL craigslist
that is a steel for a 2 ton truck only thing i change is i put a auto in it with a 700R4 and be done with it and add the wood and make it a driver
one last think i will say about old truck But the Factory Re pop wire harness for 700.00 and you will never have a wiring problem again and put the Hei in for the 6 and install power brakes and power steering and if you like Put disc brakes in just to make it more safer to drive
stsalvage is offline   Reply With Quote
