Closed Thread
Old 08-12-2010, 09:55 AM   #626
67Slider
67Slider's Avatar
Re: What did you do to your truck today!
Hung the doors on my 67. What a PITA!!!! Passesngerside took hour and a half. Driver side 5 minutes. WOW!
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 08-13-2010, 08:06 PM   #627
Davetopay
I worried that something has happened to it while I am away on vacation.
Davetopay is offline
Old 08-13-2010, 08:15 PM   #628
70cst
70cst's Avatar
Today I got the alignment done and now my truck really handles well!!
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline
Old 08-13-2010, 10:24 PM   #629
rsavage
rsavage's Avatar
Backed the Burb out of the middle bay so I could get the Harley out. Rode to the 50th Friday the Thirteenth Rally in Port Dover Ontario Canada. Thousands upon thousands of people and bikes descended on this beautiful little Lake Erie Port Village. Great time. Super day for a nice 220 mile round trip ride. Tomorrow I'll actually do some work on one of the trucks.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline
Old 08-13-2010, 10:29 PM   #630
blazin 70
blazin 70's Avatar
Replaced u joint in rear and took her for a spin.
blazin 70 is offline
Old 08-13-2010, 10:40 PM   #631
72orangeburb
My buddy & I just got my 72 K-10 Surburban running tonight after 2+ months of rebuilding the transmission & transfer case! It spent 2 years in the driveway, not being driven, because it only went backwards and I was lazy. Just the 200lb. cast iron transfer case took us 3 hours using a cherry picker down through the floor, floor jack underneath with a 2x10 board, and all the while pushing with our feet and pulling from up above to get it mounted! It was all worth it ... even though it was throwing serious smoke all the way home from the garage.
72orangeburb is offline
Old 08-14-2010, 07:35 AM   #632
eagleuh1
eagleuh1's Avatar
Replaced some cancer on my 68 C20. Got the inner rocker, lower A piller ext., front lower piller and kick pannel tacked in. Was tacking in Outer rocker to check door fit, but had to stop and unplug my econotig because of lightning storm. Already lost a computer, modem and big screan TV 3 yrs ago. Not loosing my econotig.
Man, I hate 3D puzzles. Nothing seemed to fit right. Taking longer than I expected, but getting there.
eagleuh1 is offline
Old 08-14-2010, 09:43 AM   #633
pat 70/71
pat 70/71's Avatar
carb swap/ 670cfm back to 600cfm just to much fuel for my stock motor to manage. plus, retarded the timing back to 8 degrees. the thing was burning fuel like a saturn 5 rocket!! now runs as it should. cheers, Pat
pat 70/71 is offline
Old 08-14-2010, 12:58 PM   #634
Hubscrub
Cruzin
Hubscrub's Avatar
installed my junkyard swaybar with new moog bushing boy that last bolt was a pita that stuff fits tight, haven't drove it yet
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline
Old 08-14-2010, 02:40 PM   #635
powerbench
powerbench's Avatar
order a bunch of parts from ece.....
powerbench is offline
Old 08-14-2010, 03:54 PM   #636
67Slider
67Slider's Avatar
Installed my 7.00 (= some vinyl paint) pair of junkyard visors!
[IMG][/IMG]
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 08-14-2010, 04:07 PM   #637
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I and getting ready to do the rear brakes on the blazer and not looking forward to it..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 08-14-2010, 08:12 PM   #638
SS68
SS68's Avatar
thursday and friday my carb (quadrajet) flooded on the way to work. contemplated on rebuilding it but had some truck money saved that i have been saving to buy old air ac. so today went out bought an edelbrock 600cfm 1406 w/ electric choke and put it in about an hour. now have to figure out while she idles really high. also found out my truck got hit on the new aftermarket lt bedside. to bad i wond find out out who hit it.
SS68 is offline
Old 08-14-2010, 08:15 PM   #639
Jwill41
Jwill41's Avatar
I put a new inside door handle on my daughters 98 surburban. Also bought a new radiator at O'Reillys for my 72 suburban but it got too hot outside. I will try to get it installed in the morning.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline
Old 08-14-2010, 08:30 PM   #640
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
yesterday tore part a 425 I got that I was going to use the heads off of only to find out they arn't as good as the ones I have.....
so today I pulled the heads on the 500 and pulled all the valves out put in new oil rings and lapped them all in.... well except the one that was bent.... I was surprised how well everything came out even after hearing all the horror stories about beating the fire wall back just to make it fit..needless to say the vavle covers came off used the engine hoist to pull the intake off in 1 piece unhooked the exhaust pulled the head bolts ( torqued to 115 lbs 50 years ago) hooked the hoist to it let it sit for 20 min with tention till the gasket let go the lifted it all out cleaned up the valley....tomorrow I'll start soaking the lifters till I get the gaskets on Monday....should have it back together in 2 hours....
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline
Old 08-14-2010, 08:39 PM   #641
vectorit
What?
vectorit's Avatar
Took my burb out for a 150 mile back road cruise.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 08-14-2010, 08:57 PM   #642
Hubscrub
Cruzin
Hubscrub's Avatar
pushed it up the road, after it quit getting fuel on me A BIG THANKS TO YOU 2 WHOEVER YOU WERE IN THE 67 THAT HELPED ME THANKS!
Proverbs 3:5,6
Hubscrub is offline
Old 08-14-2010, 09:23 PM   #643
AustinScott
AustinScott's Avatar
I had an itch and lost 2.5" in the front today
here is the thread LINK
AustinScott is offline
Old 08-14-2010, 09:24 PM   #644
RossRinSD
RossRinSD's Avatar
I started degreasing the front axle I picked up for the K10 like three months ago. It has disk brakes and even looks like it'll turn better.
My buddy picked up a 2008 Shelby GT500. Looks like the Camaro is gonna get some money and time spent on her just to keep up. I'll let you ladies know how it goes.
RossRinSD is offline
Old 08-15-2010, 12:20 AM   #645
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
sat in it and talked on the phone in the rain and played witht he gear shift lever..lol I cant wait to drive it
John
1999 Toyota Tacoma 4x4
oldblue1968chevy is offline
Old 08-15-2010, 12:46 AM   #646
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
I finally got the time to finish the frame clean up and today my son and I broke out the Eastwood products and got busy. I used Rust Encapsulator and chassis black (satin). Of course during the work party, we discussed using an after-market cross member, and I convinced him to go for it. So, two things to do, install the c-notch and now a new cross member.. then finish those areas ..
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline
Old 08-15-2010, 01:17 AM   #647
67chevy1series
67chevy1series's Avatar
paited my tilt colum nice red since my tuck i s black with red accents so the steering wheel was painted too
67chevy1series is offline
Old 08-15-2010, 06:32 AM   #648
project 67 sub
project 67 sub's Avatar
stole the tire pressure gage out of the center console so i could check and reduce the air pressure in the tires on my beetle
project 67 sub is offline
Old 08-15-2010, 07:59 AM   #649
72smoker
72smoker's Avatar
I repainted the front of my frame and removed the motor mounts so it will be ready for the new motor and tranny.
72smoker is offline
Old 08-15-2010, 10:42 AM   #650
chevy88
chevy88's Avatar
Ordered from board member "toomuchstuff" a heater control assembly with cables to replace a half assed installed heater controls from a 73-81 chevy truck that did not even fit the opening.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline
Closed Thread
