Old 08-08-2010, 05:39 PM   #1
brans72
engine swap from 250 to 350 small block?
Looking for info on what needs to go and what is need to swap from a 250 to a 350 small block. So far I have the 350 engine and plan on using a 700r4 transmission. So far I have pulled the old 250 and 3 speed transmission. I know I will need radiator,trans lines,possible drive shaft not sure there, crossmember since mine is gone,engine stands. So please help me out guys with what other items I will need to do the swap. Any items I can use again??? Also what about the 2 perches on the frame where trans tunnel starts has a bolt on each side that goes to 250 engine? Thanks for any help Brandon
brans72 is offline   Reply With Quote
Old 08-08-2010, 08:49 PM   #2
blime81
Laid Lo
blime81's Avatar
Re: engine swap from 250 to 350 small block?
Are you planning on mounting it in the 6 cylinder position (farther back)?
Lots of threads here on the swap.
Semper Fi,
Jeff
'72 C10 - lays frame
'07 Sand Rail - ecotec powered
'05 2500HD - tows stuff
'67 VW Bug - gas saver
'01 Jeep TJ - rock crawler
blime81 is offline   Reply With Quote
Old 08-08-2010, 10:00 PM   #3
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I have a good 200 4r trans. that will bolt up to your 350. I had it in my 72 GMC with a 355 motor.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 08-09-2010, 06:52 AM   #4
brans72
not sure on if moving engine forward or not only found one post on stands so far.
Old 08-09-2010, 06:56 AM   #5
BIG ORANGE
BIG ORANGE's Avatar
1st what yr is your truck? Get some V8 engine towers and mount them in the forward postion in the frame, meaning move the forward from where the 6cly towers were mounted.
Remove the crossmember that held the manual trans,bell housing inplace.
Your gonna need a auto sterring column,auto linkage and a auto crossmember
Depending on the yr of your truck your throttle linkage,cable could be a issue also!
From reading your post it sounds like the rest you have figured out yourself, best of luck!
Donnie
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 08-09-2010, 07:58 PM   #6
brans72
Big Orange it is a 67 SWB truck. Thanks for info there and thanks o everyone so far for input!
Old 08-14-2010, 12:16 AM   #7
pitbull784
you can run the 6cyl stands but it moves the engine back about 3-4 inches but everything still clears you can also run a floor shifter if you dont wont to covert to auto column and linkage. the auto crossmember is easy to find or you could build your own
pitbull784 is offline   Reply With Quote
