08-14-2010, 12:04 AM | #1 |
Master cylinder conversion
I have a 75 half c10. I want to convert to the 81 and up master cylinder. Do the tops on these seal better then the cast iron crap. I like the idea of a see through res and aluminum housing but not sure about the lids? Probably better if screw lid.
08-14-2010, 12:12 AM | #2 |
Re: Master cylinder conversion
My cast iron ones seal just fine?
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban |
08-14-2010, 12:18 AM | #3 |
Ive had problems with them. I opened mine up the other day and the back was bone dry. Wouldnt have happened if i could see through. Now i have to bleed the system. I take the lid off and fluid spills and splatters all over. A mess. Rust inside. Got to be a better way. Must be a reason why they upgraded them in 81.
08-14-2010, 12:28 AM | #4 |
If it was bone dry, I would be looking for a leak elsewhere. It being empty could also cause the rust in there.
Visibility may not be the real reason they switched, it was likely cost.
08-14-2010, 12:31 AM | #5 |
i'm looking to do the same. i hate the cast iron. i'm almost positive mc off an 84-86 will work. i say almost because i haven't do it yet. very soon though
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
08-14-2010, 12:58 AM | #6 |
I had an 85 nissan 720 pu with a master cylinder much like the 81 c10. Alum housing and plastic res. Never in the 21 yrs i drove that truck did i have to replace that master cylinder. I rebuilt it once. No problems. The cast iron one on my c10 has been there 2 yrs and it looks rusty and crusty inside and out. Anything painted around it is rusty too as a result of this poor design. Every time i pop the top, fluid spills from the rubber pc. No more of these cast iron jokes.
