Old 06-02-2003, 02:57 PM   #1
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Overdrive
I have a 72 Blazer and drive often it often. I would like to install an overdrive trasmission. I heard of this being done on pickups I was wondering if any one can point me in the right direction.
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 06-02-2003, 03:12 PM   #2
smokekiki
Mike
smokekiki's Avatar
on the colorado k/5 web site there is info on overdrive swaps .
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 06-02-2003, 03:23 PM   #3
Alexis
Member since 2000
Alexis's Avatar
2wd or 4wd? www.700r4.com is a site you might be intrested in. Any picture of your ride?
Alexis is offline   Reply With Quote
Old 06-02-2003, 03:38 PM   #4
68 Suburban
68 Suburban's Avatar
Check out a Gear Vendors Overdrive.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 06-02-2003, 03:48 PM   #5
smokekiki
Mike
smokekiki's Avatar
Advanced adapters has the new shaft you need to mate with the 205transfer if 4x4.The 700r4 1s 1.5-2 inch longer than a 350th.Gear vendors would be cool,a little expensive,and it will mount to back of transfer case if 4x4.
Old 06-03-2003, 09:45 AM   #6
JayDubBlazer
go cyclones
It is a 4x4, I am not going overboard with tires (no mudders or anything) I just like having 4wd. Will the 700R4 bolt into place with the exception of the transfer case? What other things do I need to consider for the price, I am still a student. Though I should have some money once the Federal Govenment lets me come home from Kuwait. Thanks
Wes
PROJECT OLE GREEN
2017 Silverado LT
