Closed Thread
Old 08-15-2010, 10:55 AM   #651
Jwill41
Jwill41's Avatar
Re: What did you do to your truck today!
I reprimered the right front fender man
We were gonna go, we were gonna go out
And get some root beer afterwards man
And I was gonna show everybody my new carburetor
And ya didn't try to call me
Frank Zappa
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline
Old 08-15-2010, 12:05 PM   #652
bigguy69
dazed and confused
bigguy69's Avatar
i walked by both of them while i was feedin the dogs. man i wished i had a garage, all this rain is killin me!
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline
Old 08-15-2010, 05:17 PM   #653
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I loaded the back with a bunch of tree branches that I pruned this morning. Then I popped the hood to check the fluids and discovered that I snapped an alternator belt sometime in the last few days..... I bet it was when I was hot rodding it yesterday and shifted at 5700 RPMs .
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline
Old 08-15-2010, 05:57 PM   #654
'Mater
'Mater's Avatar
I got my cab painted. New cab corners, rockers and floor supports were put in over the last month. A little bit of filler over the welds and lots of primer and block sanding. Temp finally cooled down so I could paint.
Turned out OK, only one run but have some dust in the paint. Just a drive so might take the time to buff when it hardens up, but might just leave it.
'Mater is offline
Old 08-15-2010, 07:10 PM   #655
67chevy1series
67chevy1series's Avatar
well worked on the cross sills for my short fleet
67chevy1series is offline
Old 08-15-2010, 07:18 PM   #656
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
put my inner fenders in
^^I like that blue!
John
1999 Toyota Tacoma 4x4
oldblue1968chevy is offline
Old 08-15-2010, 08:32 PM   #657
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Hey mater how about some more info on that 67?? Also I decided screw the rear brakes and went to the river I have a week of vac comming the 23rd sooooo Ill save up my projects for then..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline
Old 08-15-2010, 08:35 PM   #658
profe56
I did nothing, but I found this stering wheel at junkyard for 20 bucks that I will install on my next day off
profe56 is offline
Old 08-15-2010, 10:52 PM   #659
Mxracer202
Mxracer202's Avatar
^^nice find!!
Getting ready to put the new I6 (to me) in my 67, went through most of the fuel lines and replacing.
58 Jeep willys pickup
67 K10 4x4- soon to be trail truck
TROUBLE MAKER RACING
"If you can't stand BEHIND our troops, please stand in FRONT of them."
Mxracer202 is offline
Old 08-16-2010, 09:42 AM   #660
72TXSuperCheyenne
72TXSuperCheyenne's Avatar
Replaced billet grill with stock, installed emblems, mirrors (before and after pics)
72TXSuperCheyenne is offline
Old 08-16-2010, 09:46 AM   #661
Mark B
Mark B's Avatar
Finished brake lines for new MC and booster.
Mark B is offline
Old 08-16-2010, 08:19 PM   #662
oldblue1968chevy
those brake lines look TERRIFIC! I Gotta do mine...they probably will look nothing like yours..
I put water in my rad. fluid in my trans and went to start it, started up good, and only got to run it 2 minutes and I noticed a gas leak...guess the compression fitting was only good for a few tries..
And now my starter hangs up...this things really making me mad...its my dd and i havent drivin it since May really.
John
Old 08-16-2010, 11:44 PM   #663
butler57
butler57's Avatar
Beautiful day - just took it for a drive.
butler57 is offline
Old 08-17-2010, 09:17 PM   #664
btullis99
btullis99's Avatar
put in my new aluminum radiator and my new -an type transmission lines.
btullis99 is offline
Old 08-17-2010, 09:24 PM   #665
Hubscrub
Cruzin
Hubscrub's Avatar
worked on my fuel system took out tank to clean it and installed new filter and cleaned lines (since it left me pushing it saturday ha) alot of junk in the tank see filter
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline
Old 08-18-2010, 03:19 PM   #666
yote1234
yote1234's Avatar
installed fenders,carpet,ashtrey,glovebox door ect
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline
Old 08-18-2010, 03:55 PM   #667
yote1234
yote1234's Avatar
few more..
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
yote1234 is offline
Old 08-18-2010, 03:56 PM   #668
russj67
russj67's Avatar
Took my truck down to the alignment shop to confirm that my ball joints are bad. Getting them replaced next week and THEN I should finally be able to wheel her a bit! It has been an expensive few months trying to get the last of the "little" fixes done! New one piece drive line (I'll never go back to 2 piece), rebuilt rear end (also added posi ), and other minor fixes to make it feel reliable. Feel like I missed summer.
67 Stepside
Atomic Orange
Fastburn 385
TH350
The wheels are
fronts are 255-45-18 with 5" bs. 18x8 wheel
rears are 295-45-20 with 5" bs. 20x10 wheel (barely fit)
Budget: A method for going broke methodically.
You only live once!
russj67 is offline
Old 08-18-2010, 10:20 PM   #669
stevencvn72
Kill Bill...et
stevencvn72's Avatar
Lowered the passenger side 1 inch since the P.O. didn't know how to cut springs the same amount on both sides. Tomorrow, a trip to Ace for new hardware so I can get the same size suspension bolts on both sides.
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline
Old 08-18-2010, 11:35 PM   #670
Shyguy
Junior Member
Shyguy's Avatar
Today was a good day, it was not too hot for a change. I did not get anything done on my trucks, but said hi to them.
I inventoried my truck parts, straightened the garage a little and checked out the head lights on the '86 4Runner. I figure the best way to get the lights to work on high and low beam will be to put in all new wiring with relays and a multi position toggle switch.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline
Old 08-19-2010, 12:04 AM   #671
my70chevyc10
my70chevyc10's Avatar
Installed 12 new wheel studs today after the left front tire fell off as i was pulling into the auto parts store.
"Your trucks fast! You must have been going 120 when I passed you."
"Owning A 10 Sec Import Is Like Coming Out Of The Closet, In The End Ur Still Gay"
If for some reason i loose to a import...At least i can go home knowing the vehicle i drive drops girls panties...
my70chevyc10 is offline
Old 08-19-2010, 09:35 AM   #672
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Actually did it on Tuesday... Welded up a new 3" exhaust from the headers back using Flowmaster 40 series mufflers. Dumped it out in front of the rear tires at an angle...so the opening looks like a 4" wide oval...
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
GASoline71 is offline
Old 08-19-2010, 04:53 PM   #673
bigdogboxers
bigdogboxers's Avatar
Its been slow going with the 1970 4x4... Finally got a new windshield installed for $165 and moved the truck out to the parking area so my wife could have her carport back for her 1998 camaro convertable... I was so impressed with how it was running i went to start it up for my wife to hear it for the first time since i put my new bolt on 2 1/4 inch bolt on exhaust from lmc (fit like a glove) never got it to start i literally broke the starter in 2 pieces.... question ? anyone know why the starter would brake into pieces?
bigdogboxers is offline
Old 08-19-2010, 05:05 PM   #674
68 TT
Still plays with trucks
68 TT's Avatar
Originally Posted by bigdogboxers View Post
...i literally broke the starter in 2 pieces.... question ? anyone know why the starter would brake into pieces?
Did the aluminum snout break in half or did the body separate from the snout?
I have had a couple reman starters that the bolts holding the starter together were either overtightened and stripped out so they wouldn't hold torque or were not tightened enough right out of the box.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline
Old 08-19-2010, 05:11 PM   #675
bigdogboxers
The aluminum snout broke.. it is a high performance 327 with 202 camel humps and 2 1/4 exhaust with ram horn manifolds.. it does have lots of compression.
Closed Thread
