Quick fender removal? On a 94
Ok I know the basic stuff here ok! My local junk yard had free parts days and its all you can carry out for one price. Now I want to remove two front fenders with the inner fenders still attached. I can only carry minimum tools. Has anyone removed as a one piece assembly?
Thanks Alan |
Re: Quick fender removal? On a 94
For U-Pic & Pull parts I'll normally carry my Craftsman Tool Bag
gloves a rack of 3/8 drive standard & metric sockets Rachet extensions swivel screw drivers vice grips pliars wire cutters rack of standard & metric open/box end wrenches That should be pretty much all you need. If you bring along an extra pair of hands that would make it much easier because OBS hoods are heavy and the hinges attaches to the fenders. Last edited by Bigg G; 08-17-2010 at 11:29 AM. |
That's how they are installed in the plant: with the wheelhouse already attached to the fender.
I would think it could come apart the same way. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 08-17-2010 at 12:58 PM. |
1 13mm on the bottom of fender straight up,
2 13mm inside of door, 1 13mm under hood hinge, 2 13mm in the inner well to cab. 3 13mm straight up inner fender to rad support, 3 13mm from support to fender. 10mm to get the coolant bottle off. and the washer bottle. Thats it on the fenders. Just need about a 12inch ext. inside the door,unless you take the doors off. I just rebuilt my truck..and took another apart..both 94's |
Old Skool Club
![]() Join Date: Jun 2001
Voice of experience, right there.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
| Bookmarks |
