Old 08-18-2010, 02:58 PM   #1
JGross
15 inch wheels with front disk brakes, Will it work?
I will be putting rotors and disk brake calapers from a 73 C10 on the front of my 65, will 15 inch wheels fit over the calapers?
JGross is offline   Reply With Quote
Old 08-18-2010, 03:31 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: 15 inch wheels with front disk brakes, Will it work?
As long as the 15" wheels were designed for disc brakes, no problem. Some factory wheels that were built for drum can interfer with the caliper.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-18-2010, 05:10 PM   #3
TheDark1
Intentionally Left Blank
TheDark1's Avatar
I have 15x8 inch wheels with the Early Classic Enterprises disc brake kit and I've had no problems.---jeff
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
Old 08-18-2010, 05:49 PM   #4
jocko
jocko's Avatar
excellent question and here's a follow-on:
Same problem I had with a 55 first series - I wanted to run stock steel wheels but all disk brake kits would result in interference. Disk kit dealers all said a spacer (I forget the size, but it was slim) would resolve the problem.
Does that hold true for 60-66? In other words - for those that have run into this problem, exactly where does the interference with the caliper occur for stock steelies? (a diameter or depth/offset issue?)
Thanks,
jocko
Old 08-18-2010, 05:55 PM   #5
TheDark1
TheDark1's Avatar
Sorry, I forgot to mention that I have after market aluminum wheels.
1997 Formula WS6
Old 08-18-2010, 06:29 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
The caliper interference occurs with the tapered backside of the pre-disc brake wheels. Almost all steel wheels prior to disc brake had a cylinder shaped front side and a conical/tapered rear shape to the rim, for ease of installing the tire. When discs came along, they simply made the back of the wheel cylinder shaped like the front, providing more clearance between the back of the wheel rim and the caliper.
Although the photo below is an early Radir mag, it uses an original pre-disc brake rim. I've marked the tapered area that normally causes the interference:
Old 08-18-2010, 06:48 PM   #7
jocko
jocko's Avatar
now i get it. great explanation markeb01, thanks very much.
Old 08-18-2010, 07:15 PM   #8
padresag
I just made a 1/4" spacer and it works just fine for the last 16 or 17 years and I am running 8 lug on my 4 x 4
ron
padresag is offline   Reply With Quote
Old 08-18-2010, 09:03 PM   #9
jocko
jocko's Avatar
are 8 lug whls 15" or 16"?
Old 08-18-2010, 09:44 PM   #10
padresag
can be either or 17"
By rondavid at 2010-08-18
an original 15"-8lug' I did use a later 15 x 8 white spoke wheel
ron
Old 08-19-2010, 08:47 AM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I have 15 in Mickey Thompson aluminum wheels and they clear my manual front discs fine.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-19-2010, 10:10 AM   #12
Clyde65
Clyde65's Avatar
I have 80's GM Truck 15x8 Rallye wheels on my 65. I have a 72 disc front suspension
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
