gas sender
I'm replaceing the tank sending unit in the 65, I think I have 1/4 to 1/2 tank of gas. Question is how much gas (if any) will flow out of the line from the engine to tank and sending unit when I disconnect it ? Thanks.
Re: gas sender
If you have only a quarter tank no gas should come out, not sure about the half way point thou, you should also use a long ground strap and keep it grounded while you are removing the sending unit out as not to generate any static electricity....same with install..
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Re: gas sender
If you have the in cab gas tank I don't think any will come out.
When I removed the sending unit from my truck the only gas that I got in my cab was what dripped off the float. I think it's because the connector for the fuel pick-up on the sending unit is on the top of the tank; fuel can't siphon out if the end of the pipe is above the level of the fuel in the tank. |
Re: gas sender
Thanks guys, I didn't want to flood my cab.
Re: gas sender
Be sure to keep your windows open. Just b/c no liquid gas gets in your cab doesn't mean its safe. Fumes will still be escaping from the sender hole.
Re: gas sender
changing the sending unit in the cab is pretty easy. As said above "only gas that I got in my cab was what dripped off the float"
Last time I changed mine was on my lunch our at work. took about 10-15 mins. I kept my doors open. Might be a good idea to disconnect your battery. just a thought. I dont believe I disconnected mine when i did it though.
1966 Chevy C10 Stepside 355ci sbc with 3speed OD 2021 GMC Sierra 1500 AT4 6.2 1980 Chevy Camaro z28 383ci 1990 Chevy Suburban 350 tbi 2x4 (sold) 1984 Chevy C10 sliverado short fleet 1997 Chevy C1500 short fleet Last edited by NCD1966; 08-19-2010 at 05:56 PM. |
