Closed Thread
Old 08-19-2010, 05:34 PM   #676
68 TT
Still plays with trucks
68 TT's Avatar
Re: What did you do to your truck today!
Originally Posted by bigdogboxers View Post
The aluminum snout broke.. it is a high performance 327 with 202 camel humps and 2 1/4 exhaust with ram horn manifolds.. it does have lots of compression.
You should look into getting a starter from a 90 to 96 full size 4x4 truck. They are a little smaller but have a higher output than the older starters. The 4x4 versions have a smaller opening in the snout to help prevent debris from getting in there when off road driving. The 2wd versions have the typical large opening in the snout but are a little cheaper. About $60 at AZ with a lifetime warranty.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline
Old 08-19-2010, 05:38 PM   #677
68 TT
68 TT's Avatar
S10's & Astro vans used the starters too from 88-95 on the S10 and 91-96 on the Astro plus full size vans too so if you are on a tight budget you can get one from Pull & Save for under $17 out the door.
68 TT is offline
Old 08-19-2010, 06:17 PM   #678
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Now that AI'm back running on all 8.2 liters I made the right rear tire a little balder??
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline
Old 08-20-2010, 11:05 AM   #679
stevencvn72
Kill Bill...et
stevencvn72's Avatar
Brake caliper hardware rebuild kit...$7, Trip to Ace for some grade 8 hardware for the front susp....$15. Now I can travel down the road with my mind at ease.
-Steve
I Grease
'67 Chev stepper
http://youtu.be/38p_2Iu2fd0
stevencvn72 is offline
Old 08-20-2010, 07:05 PM   #680
grayharville
^^who I am^^ what I say>
grayharville's Avatar
I put gas in it! Good god, that cost as much as the truck did.
70 chevy LWB 350/TH350 Barn find (AKA the 70)
http://www.67-72chevytrucks.com/vboa...d.php?t=406364
East Tx Squares
grayharville is offline
Old 08-20-2010, 08:17 PM   #681
Hubscrub
Cruzin
Hubscrub's Avatar
got it back on the road
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline
Old 08-20-2010, 09:28 PM   #682
sjarrett71
sjarrett71's Avatar
Fixed my fuel gauge by replacing the float on the sending unit. The old one was full of gas.
-Scott-
sjarrett71 is offline
Old 08-20-2010, 10:45 PM   #683
jdcole
jdcole's Avatar
Painted the bottom of the cab and going to prep the inside
1969 Chevy LWB 350 converting to short stepper
My build thread
jdcole is offline
Old 08-21-2010, 08:04 AM   #684
eagleuh1
eagleuh1's Avatar
Finished welding in inner rockers, floor patch, a pillar and fender brace on passenger side. Painted with por 15. Also painted under arm with por 15 while painting bottom of cab laying on floor. Didn't notice drips into shirt sleeve untill to late. Wife couldn't stop laughing. Now on to the cab corner and outer rocker.
eagleuh1 is offline
Old 08-21-2010, 04:27 PM   #685
btullis99
btullis99's Avatar
changed the oil and had helpers. installed new 1 piece driveshaft from driveshaft specialists, and put a new rear trans seal while i was at it.
btullis99 is offline
Old 08-21-2010, 07:29 PM   #686
67Slider
67Slider's Avatar
[QUOTE=btullis99;4150595]changed the oil and had helpers.
Very cool. I love it when my boys give me a hand. Didn't do a thing today but started it in the garage yesterday.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 08-21-2010, 07:46 PM   #687
Davetopay
Went outside thinking I needed a starter, just had a loose wire. So I loaded some of my guns up and spent some quality time at the range.
Davetopay is offline
Old 08-21-2010, 10:51 PM   #688
LSX72C10
Worked on some Turbo Piping. Hopefully hear this thing run really soon.
LSX72C10 is offline
Old 08-22-2010, 09:29 PM   #689
oletimer72
oletimer72's Avatar
installed outer inner headlight trim also rattle caned all my brackets.......
oletimer72 is offline
Old 08-22-2010, 09:51 PM   #690
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Worked on some brake lines and got some free parts from a junked truck
John
1999 Toyota Tacoma 4x4
oldblue1968chevy is offline
Old 08-22-2010, 10:02 PM   #691
grayharville
Got my heater to quit working. It was 100 degrees outside today, and i drove about 50 miles with the heater blowing, that inspired me to fix it REAL quick.
East Tx Squares
Old 08-22-2010, 10:15 PM   #692
vectorit
What?
vectorit's Avatar
Drove her around town.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline
Old 08-22-2010, 10:29 PM   #693
pat 70/71
pat 70/71's Avatar
today I pulled my gas tank (under bed stainless steel) I had fuel pressure issues. found a rubber glove in the tank (no extra charge) the most crazy discovery I've made to date! Truck would run great! then all of a sudden fall on its butt & starve for fuel(only with 3/4 of a tank or more) go figure! anywho, thing works fanfriggintastic now & once more I love my truck! cheers, Pat
pat 70/71 is offline
Old 08-22-2010, 10:30 PM   #694
Installed my new fuel cell. Picked up a new rear sport bumper. Then the usual, sanding and prep for paint.
Palf70Step is offline
Old 08-22-2010, 10:36 PM   #695
pat 70/71
pat 70/71's Avatar
really enjoy your little helpers! they grow up so fast! great photo, may you always enjoy the help! (take many pictures ) cheers, Pat
Old 08-22-2010, 10:59 PM   #696
05crewcab
05crewcab's Avatar
It was a good weekend
yesterday i changed the water pump and alternator and painted all my pulleys and inner fenders...
Today i "isolated" my grill to stop some squeaks, cleaned up a little wiring, and I drove around the city lakes and scouted out some trim pieces
1971 C-20 350/350
05crewcab is offline
Old 08-23-2010, 12:08 AM   #697
Sven
Sven's Avatar
Replaced the upper and lower radiator hoses, the radiator cap and refilled her with Prestone 50/50. She had a senior moment late last night, got all hot and bothered and pee'd all over my driveway.
Cut out the passenger side upper seat belt anchor as the spot welds had broken and the upper anchor was rattling. If I knew before what I know now I would have just drilled above and below the nut and used those holes to plug/spot weld the inside support thingy to the sheet metal. Now, I have to weld the sheet metal back in, sand it, smear on some bondo, sand, repeat a few times and then repaint.
-Steve
1969 Chevrolet 4x4 C10 Pickup
Sven is offline
Old 08-24-2010, 11:06 PM   #698
flashed
Got my front end aligned and my van ralleys put on .Still looking for 2 truck ralleys nearby .
flashed is offline
Old 08-24-2010, 11:32 PM   #699
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
I checked on line to see when my parts would be here from CPP.
I can't wait any longer!!
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline
Old 08-27-2010, 10:30 AM   #700
POPO1984
POPO1984's Avatar
Fixed my rusted core support. Used a piece of the bed support that I cut out for the blazer tank. worked pretty good. Yeah I know my welds are ugly.
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline
Closed Thread
