Old 08-16-2010, 05:02 PM   #1
timcrow00
transfer case swap
will a case from a 88 k3500 5.7 th400 work on my 93 k2500 5.7 4l60e?
timcrow00 is offline   Reply With Quote
Old 08-16-2010, 06:19 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: transfer case swap
Ttt
Member Nr. 2770
Old 08-20-2010, 05:24 PM   #3
timcrow00
lil help here
Old 08-20-2010, 05:32 PM   #4
Ghastlyone
Ghastlyone's Avatar
Your 93 has a 4L60E?
Ghastlyone is offline   Reply With Quote
Old 08-20-2010, 06:31 PM   #5
timcrow00
yeah from what i hear 93 was the first year for the 60e
Old 08-20-2010, 06:38 PM   #6
Ghastlyone
Ghastlyone's Avatar
Huh, interesting.
I've always heard the 4L60's started in like 94 or 95? Maybe I heard wrong.
Old 08-20-2010, 07:05 PM   #7
BigBlocksRule
Nope, '93 was the first year. Been there, done that. I think that the '93 - '95 are the same and they changed after that.
Bolt patterns are different from a TH400 to a 700R4/TH350. You might be able to get it done, but it'll take at least an adapter. There should be plenty of NP203's out there with the TH350/700 pattern, I sold two not long ago for $50 apiece.
BigBlocksRule is offline   Reply With Quote
Old 08-20-2010, 08:21 PM   #8
benoit454
Chris
benoit454's Avatar
203 that's a full time case aint it? did the 3500's use them? I thought a 203 went out back in the 70's.
But yea 700r4 and th350 have a 4 bolt tail pattern and 400 is 6 bolt, now a 4l80 I hear is the od replacement/same as th400? Not sure on the tails though. but a 4l60 is the same as the 700r4 or so I've read and seen online.
I also think the 400 is a 32 spline and 700r4's and th350's are 27, so splines might be different too. if not then yea an adapter should be all you need. except for maybe differences in length if they are different cases or something?
Chris
GIT R DONE!!!!!!
Check out all our rides,
