How TO Remove T-Case Floor Shift Cover
simple question i know,, but i can't see how you remove the plastic trim cover from over the transfer case shifter. It's on there really firm, can't see how to pop it off or access to any screws that would be holding it down??
the pollock
Re: How TO Remove T-Case Floor Shift Cover
two screws on the "forward" flat side.
there are two screws on the flat side facing the seat. also unscrew the knob and one the plastic is off theres about 10 bolts there when you remove the shifter assy youll need to remove the cotter pin to disconnect it from the transfer case
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
| Bookmarks |
