Old 08-23-2010, 06:31 AM   #1
masterlock
masterlock's Avatar
Need help 2 questions
First question:
I have a 77 c10, when in first and second gear there is a loud "spinning" sound, thats the best way to describe it, comming from the transmission. It sounds almost like loose bearings or something. In third it is silent, just sounds normal. Anyone know what the issue could be?
Second question:
If I remove the stock air cleaner and install an Edelbrock pro-flow what do I do with the tubes that are hooked up to the neck of the factory air cleaner intake. Can I just get rid of them or is there something else I need to do.
Thanks in advance guys I am new to the whole truck game and you are really the only ones i have to answer my questions.
masterlock is offline   Reply With Quote
Old 08-23-2010, 07:22 AM   #2
big10ratrod77
big10ratrod77's Avatar
Re: Need help 2 questions
dose it grind in gear? what trannie do you have?
well you can remove the factory hot air pipe (thats what i call it) it just brings hot air from the manifolds to you air cleaner so it dont stumble when its cold. how cold dose it get in your neck of the woods? here in nc when it gets cold my choke will hardly cut off on my 77 without it. i had an edelbrock pro-flow on my 77 but i ditched that for my stock air cleaner with the lid turned upside down with a correct size K&N air filter and this a good workin set up couse on the cold mornings i can put that pipe back and turn the lid over and it dosent stumble as bad which makes me look better when i dont choke it off first thing pulling over the speed bump at skool. lol
masterlock is there eny chance we can here more about the truck?
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 08-23-2010, 07:35 AM   #3
masterlock
masterlock's Avatar
It doesnt get cold here, 70-80 every day, kinda sucks honestly, I like weather. Anyway, It has a 350 and matching tranny im pretty sure it is all original. The sound isnt grinding it sounds like something is spinning like I said like spinning bearings. It does not happen in third, its a three speed manual. The guy that had it before me converted it to a floor shifter. Not sure what else to mention, again Im new at this so the more specific questions the beter I can answer.
But back to the vacuum hose issue, I can just remove that hose and not worry about anything?
Old 08-23-2010, 01:06 PM   #4
BigRed76
BigRed76's Avatar
Now that you mention that its a manual, my truck does the same thing in 1st and 2nd gear,and when the truck is idling in nuetral you can really hear it. My dad said it was from the bearings being worn out/damaged from not being properly maintained. I dont plan on doing anything about it since i plan on swapping it out for an NV4500 soon.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 08-24-2010, 03:27 AM   #5
masterlock
masterlock's Avatar
yeah thats what it sounds like, Anyone know what the price to replace the bearings would be? I figure I should fix it now before it gets worse.
Old 08-24-2010, 08:36 AM   #6
tucsonjwt
No smog test in Cali? In AZ, they check all of the connections to the carb and air cleaner, even if not directly smog related. During my last trip throught emissions, the boss came out of the office and checked over my engine for 20 minutes before they let me through - and I had everything stock set up. That is why I don't like aftermarket carbs - you end up with a cobbled up mess trying to hook everything back up - unless you just plain eliminate what doesn't hook up. I say stick with the stock set up - but each to his or her own.
tucsonjwt is offline   Reply With Quote
Old 08-24-2010, 09:24 AM   #7
BigRed76
BigRed76's Avatar
you would have to get some price quotes for a transmission rebuild from your local shops
Zach
