Old 08-23-2010, 11:21 AM   #576
68 TT
Still plays with trucks
68 TT's Avatar
Re: 67 cheby's Dropmember build thread
Originally Posted by 67cheby View Post
good news...sold the Dune Buggie , started working on the truck again last night put the rear disc brakes back on (should be the last time the rear end is completely powder coated and done, minus running the brake lines)NOW.... back to the "NIGHTMARE FRONT INNER FENDERS"
Any chance a set of rear tubs could be made to work easier? With the flatter shape it would be much easier to blend into to change the coverage area and height. Just a thought.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 08-25-2010, 09:51 AM   #577
colin_havens
colin_havens's Avatar
That looks MUCH better. Those will look great once finished out.
colin_havens is offline   Reply With Quote
Old 08-25-2010, 09:53 AM   #578
my67chevytruck
Under Construction
my67chevytruck's Avatar
I like it...... transitions alot better.....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 08-25-2010, 10:00 AM   #579
67cheby
67cheby
67cheby's Avatar
thanks for all of your input , it is appreciated, this was my last idea , so hopefully it will turn out looking right, im thinking about shooting it with a quick coat of spray paint ,satin black , so i can get a little beter idea of what it will look like finished, the fenders flare in the front and rear, which is kind of cool because it gives extra turning room
67cheby is offline   Reply With Quote
Old 08-25-2010, 11:17 AM   #580
68 TT
68 TT's Avatar
That made a huge difference. It looks much better now. Great idea. Keep up the good work.
Old 08-25-2010, 12:06 PM   #581
67cheby
67cheby
67cheby's Avatar
68tt i havent forgot about the measurements for you, i just need to figure out for sure which way to measure what you are looking for
Old 08-25-2010, 12:45 PM   #582
68 TT
68 TT's Avatar
Put it at full drop as low as you want it to get and measure how high the center of the diff is above the original section height of the frame rails.
You can use your bed mount rails as a reference point to see how close it will be to the bed floor if you don't have the bed on or available.
If the diff is not going to poke through the bed at the resting point you want to achieve then it might be worth the effort to rework the frame notch structure to try to get it all below your relocated bed floor.
Old 08-25-2010, 02:51 PM   #583
SCOTI
SCOTI's Avatar
Here itis.... added a little vw influence to it, took 4 inches off of my inner fenders and welded a piece of a bug fender to it
MUCH better!
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-25-2010, 02:56 PM   #584
67cheby
67cheby
67cheby's Avatar
Originally Posted by SCOTI View Post
MUCH better!
is "much better" good or is much better, "they looked like crap before so they couldnt get worse this is an improvement"??
Old 08-25-2010, 02:56 PM   #585
edflores
Here it is "back in the saddle again" been working on it every night , added a little vw influence to it, took 4 inches off of my inner fenders and welded a piece of a bug fender to it
Now that is using your noggin. Fantastic job!!
edflores is offline   Reply With Quote
Old 08-25-2010, 03:03 PM   #586
67cheby
67cheby
67cheby's Avatar
Originally Posted by edflores View Post
No that is using your noggin. Fantastic job!!
i didnt think that my love for vws would ever have any effect on my Chevy .....but hey , i guess you never know, what some crack head will dream up, it should be a fun conversation piece at shows
Old 08-25-2010, 03:11 PM   #587
68 TT
68 TT's Avatar
The square edge just didn't look right and threw off the whole look. The rounded contour really made a big change to the whole look of it. Now "much better" means they look good.
A little contouring at the forward transitions to the original inner fender will finish the look.
You are on the right track and making good progress.
Old 08-25-2010, 03:46 PM   #588
LEEVON
Moderator
LEEVON's Avatar
You nailed it, much more subtle.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 08-25-2010, 04:03 PM   #589
67cheby
67cheby
67cheby's Avatar
Thanks Leevon and i am serious about the help , just let me know
Old 08-25-2010, 08:56 PM   #590
watahyahknow
watahyahknow's Avatar
great idea i wouldnt have come up with it unless i had the stuf laying around and would be in a creatve mood , it looks a lot more like it belongs there than a trailerfender , i wouldnt be suprized if there more people that going to use this trick in the furure
i've seen sumtin simulair used once when the set an engine back inside a car and needed to put the firewhall back
they used part of the bucket of a wheelbarrow they just cut it to size welded it up and they where done in no time flat , looked good too with the compound corners on the bucket and all that
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 08-28-2010, 01:29 PM   #591
67cheby
67cheby
67cheby's Avatar
here is a pic that i think might give you and idea, the bottom of the axle tube sets about even with the top of the old frame
Old 08-30-2010, 02:58 AM   #592
trenz68
Damage Inc
trenz68's Avatar
looks good
05 CC- magnacharged,LTs,Gt-2 cam,3.73s,tru-trac,tuned-sold
01 ECSB- caddy-clipped,22/24 intros,cammed,layin-frame
04 RCSB-joe gibbs clone,22in billets
68 stepper build
http://67-72chevytrucks.com/vboard/s...d.php?t=332337
trenz68 is offline   Reply With Quote
Old 08-30-2010, 11:35 AM   #593
68 TT
68 TT's Avatar
Looks like it is about 9" above the top of the frame rail at the center line of the axle. How tall is the frame notch?
Old 09-01-2010, 10:59 AM   #594
68 TT
68 TT's Avatar
It is really starting to take shape. That little change to the wheel wells really made a big difference. Great work.
Old 09-01-2010, 11:17 AM   #595
67cheby
67cheby
67cheby's Avatar
thanks, i have alot of work left but im getting there!!
Old 09-01-2010, 11:44 AM   #596
RocketKing
RocketKing's Avatar
Man, that is one great lookin' air cleaner.
Rex
RocketKing is offline   Reply With Quote
Old 09-01-2010, 11:50 AM   #597
67cheby
67cheby
67cheby's Avatar
Thanks there is a great story behind it maybe i will tell you about it sometime !!LOL
Old 09-01-2010, 11:52 AM   #598
BlackTopMotors
Looks Great! Keep them pics coming!
BlackTopMotors is offline   Reply With Quote
Old 09-01-2010, 12:25 PM   #599
superflysteiny
superflysteiny's Avatar
looks great really coming along
superflysteiny is offline   Reply With Quote
Old 09-01-2010, 12:27 PM   #600
67cheby
67cheby
67cheby's Avatar
Thanks Blacktop and Superfly , i appreciate the response..kinda keeps me motivated
fiberglass inner fenders, pb hood hinges ", w/pb 4 link
