Old 08-25-2010, 09:50 PM   #1
-dylan-(OO==|==OO)
I dont drive fast,, I fly low!
-dylan-(OO==|==OO)'s Avatar
lowering questions????
im wantingto lower my 67 gmc. it has leafs in the back, andi was wondering how would i g about notching it and bagging it with leafs? And any websites that will have te best prices on notches
____________
/_______\
(OO==||==OO)
67 GMC CUSTOM,72 GMC...65 chevelle...65 fastback mustang...75 VEGA...90 lx mustang...90 supercoupe...90 jeep wrangler...04 mach 1 mustang...06 toyota tacoma...08 nissan altima
-dylan-(OO==|==OO) is offline   Reply With Quote
Old 08-25-2010, 09:53 PM   #2
-dylan-(OO==|==OO)
im wanting to lower my 67 gmc, but it has leafs int he back, wat are some ways that i can go about notching and bagging with leafs? and if you have any website with good prices on notches ... let me know
____________
/_______\
(OO==||==OO)
Old 08-25-2010, 09:53 PM   #3
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: lowering questions????
I like Early Classic Enterprises. I have their 2.5/4.0 drop on my '69 SWB Chevy. Of course, there are other vendors including some on here.
Member Nr. 2770
Old 08-25-2010, 09:59 PM   #4
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
ECE is nice for suspension, whats your budget first and how low ya wanna go?
John
1999 Toyota Tacoma 4x4
Old 08-26-2010, 03:00 PM   #5
-dylan-(OO==|==OO)
ummm im not really sure on the budget, i dont know the price ranges of them? and as far as how far i wanna lower it.... all the way.
____________
/_______\
(OO==||==OO)
Old 08-26-2010, 04:18 PM   #6
SCOTI
SCOTI's Avatar
CPP has a standard & HD bolt-in c-notch.
Porterbuilt has a bolt-in step notches @ differing heights depending on your needs.
SuicideDoors has step notches.
KP Components has step notches.
On your leaf equipped truck, a flip kit gets you around 5-6" of drop. To match that, you'll want spindles, dropped springs, & optimized shocks (different shocks or brackets).... or an aftermarket xmember.
If you want bags out back, your options are parallel 4-bar, converging 4-bar, 3-link, KP Components 6-link, Extensive metalworks 2-link (not to be confused w/a factory 6x-72 GM truck truck arm set-up), & aftermarket truck arm set-ups (Porterbuilt has one that allowns the rails to lay). To compliment these, you'll change out the front coils for bags.
That should be enough homework for now.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-21-2011, 12:18 PM   #7
papsoldblue72
papsoldblue72's Avatar
ok need a little help ..... I want to lower the rear of my truck it has leaf springs and i see that you can purchase a flip kit .... well i am too cheap to do that .... and i really don't want to hack the frame up... can i just take the spring apart and use like one or two of them to get my ride a little lower i mean i really don't want to be on the ground .... just a little lower like 1 or 2 inches would be great .... Thanks
papsoldblue72 is offline   Reply With Quote
Old 07-21-2011, 12:39 PM   #8
SCOTI
SCOTI's Avatar
Yes, you can remove leaves & it will drop the height. It will also lower the load capacity & allow a higher possibility of wheel hop under acceleration or braking.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-02-2011, 11:19 AM   #9
sneezys72
I pulled the overload and the next spring. I also used a 1" drop shackle. Lowered the rear 3.5". No wheel hop, and still able to load it up if I need to.
sneezys72 is offline   Reply With Quote
Old 08-02-2011, 02:19 PM   #10
papsoldblue72
nice ............ Thanks for your help .......
Old 08-02-2011, 06:16 PM   #11
SCOTI
SCOTI's Avatar
What does the drivetrain consist of?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-03-2011, 09:17 AM   #12
papsoldblue72
Old 08-03-2011, 09:21 AM   #13
papsoldblue72
Nothing right now. I have a 427 big block and a 350 turbo trans. I plan to use. The truck was a 305 with a 3 speed manual trans. Later on I'll probably swap out the trans for a 5 speed manual I just like shifting those gears ..... I put a link of a video i shot after getting it home.
Old 08-03-2011, 09:22 AM   #14
papsoldblue72
Old 08-03-2011, 08:16 PM   #15
sneezys72
I have a 350. Originally it had a th350, now it has a 700r4. I should add that it still has 3 springs in it.
Old 08-06-2011, 09:51 PM   #16
papsoldblue72
Cool can you post some pictures for me ????
It's been a long time coming... It's time to get it done..
Old 08-11-2011, 10:21 PM   #17
sneezys72
Sorry it has been awhile. What pics would you like?
Old 08-12-2011, 08:51 AM   #18
papsoldblue72
some of the rear axel setup you have ...
Old 08-13-2011, 06:41 PM   #19
sneezys72
Not sure if these will help much. I have a pic of the drop shackle. It is from ECE and is a 1" drop. I included a pic of the 3 springs in the truck. I also included a pic of the 2 I took out. If you would like more let me know. I can pull a wheel off later this week if you would like that pic. With those 2 springs taken out, and the drop shackle, it lowered my truck about 3.5"
Old 08-13-2011, 10:24 PM   #20
papsoldblue72
Thanks so much that is very helpful just what i was looking for .....
Old 08-13-2011, 10:27 PM   #21
papsoldblue72
just one more favor can you take a picture of your truck.... just so i get an idea of how low it is...... thanks
Old 08-21-2011, 12:22 PM   #22
sneezys72
Will do. Will try today or tomorrow.
Old 08-22-2011, 05:01 PM   #23
sneezys72
Here is a side pic of my truck. Not the best but my street isn't very level. It gives an idea though. This is my truck lowered 3.5" all the way around. I am thinking of dropping the rear 1-2" more. I don't mind the rake, just want a little less. Sorry it's dirty, we had a dust storm the other night and I haven't had time to clean it yet. Hope that helps you.
Old 08-22-2011, 05:12 PM   #24
papsoldblue72
Thanks so much ..... You have been alot of help .... I think I am gonna do the same thing to mine.... I'm gonna wait to lower the front till i get the engine together and in because I just don't know how low it will make it with me changing from a small block engine to a big block ..... Thanks again.....
Old 08-26-2011, 03:01 PM   #25
sneezys72
Any time. I had a hard time finding info when I lowered mine. Just decided to do it. Makes it easier when someone can help out.
