08-25-2010, 05:53 PM | #1 |
? about painting tail light housings.
will painting the back side [part you can't see when installed] on the tail light & reverce light housings mess up my grounds or anything ? thanks for any help.
i have 67/72 chevy truck parts f/s. |
08-25-2010, 06:13 PM | #2 |
Re: ? about painting tail light housings.
Not if you use star washers and torque down hard hard enough for the washers to cut into metal. Also make sure the bed is grounded to the frame.
72 Fleet (died) 78 Step (sold) 55 Step named Fred (sold) 00 F150 68 Step (named El Scorcho by PO) Build thread for the new El Scorcho http://67-72chevytrucks.com/vboard/s...d.php?t=392932 |
08-25-2010, 07:18 PM | #3 |
PROJECT 7DEUCE
I usually powdercoat em chrome and use a dremel to clean a ground surface on the backside for the ground wire to attach to.
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-25-2010, 07:53 PM | #4 |
The original fasteners have washers with built in serations and if they are in good condition painting will not affect the grounding.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
08-25-2010, 10:15 PM | #5 |
ok thanks for the info. bill
