08-26-2010, 12:27 AM | #1 |
Master Cylinder Bad?
I went to replace my front brake hoses today, and as soon as I disconnected the passenger side brake hose, fluid began running out of the steel brake line. It continued to run until it drained the front reservoir of the master cylinder completely. I don't know for sure, but I wouldn't think that this should have happened.
Please advise!
1972 Chevy C-10 ~ 188,000 miles give or take |
08-26-2010, 12:43 AM | #2 |
Re: Master Cylinder Bad?
Nothing unusual with this. Perfectly normal.
My build thread. |
08-26-2010, 12:52 AM | #3 |
Phew. Good to know.
08-26-2010, 01:15 AM | #4 |
On another note. I think my proportioning valve is sticking. Occasionally, the brake light comes on, and won't go off until I hit the brakes hard. I usually hear something click when that happens. Is there anything that I can do to fix this, other than replacing the proportioning valve?
08-26-2010, 07:51 AM | #5 |
have you pulled off the rear drums and checked for indications of leaking wheel cylinders???
08-26-2010, 11:39 AM | #6 |
Negative. Not yet. Could that cause the proportioning valve to stick?
08-26-2010, 12:04 PM | #7 |
Old Skool Club
It may be that the "188,000 miles, give or take" caused the proportioning valve to go bad.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
08-26-2010, 12:07 PM | #8 |
That's kinda what I was thinking. It doesn't look like regular auto parts stores sell them either. . .and at LMC they're quite pricey.
08-26-2010, 08:10 PM | #9 |
Incidentally, what the heck size wrench fits the compression fitting between the brake hose and the brake line???
