Old 06-05-2003, 09:00 AM   #1
VNMOUS
Step Side's Rule
Camshafts
What is the best camshaft to use? I'm not looking for anything real radical, just something low RPM.
DANO
07 Silverado Classic
67shortstep
76 stingray
95 cobra
66 Mustang Coupe 289
VNMOUS is offline   Reply With Quote
Old 06-05-2003, 09:23 AM   #2
Old Chevy
Old Chevy's Avatar
comp cams comp extreme 268, I hear nothing but praise for this one.
cheers
Richard
Broken Arrow, OK.
1977 Corvette, ZZ4 Crate, new interior, new suspension, new driveline, you get the picture, (new project / daily driver)
Old Chevy is offline   Reply With Quote
Old 06-05-2003, 09:32 AM   #3
crazy longhorn
Fabricate till you "puke"
One that i like for a daily driver/hauler, is a Crane Energizer 266. I run 1 in the 355 in my plow truck......stock type idle, & plenty of low end grunt. You might also look at the Comp HE 260. If you are building more for perf, the XE cams are good performers, but you should have lower rear gears, & a looser converter(2500 stall is about right for the XE 268). Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-05-2003, 01:20 PM   #4
Blue68
Blue68's Avatar
Call or email Comp Cams and provide all your information, vehicle, weight, rear gears, transmission, engine displacement, engine year (roller or flat tappet), carb, intake,heads and above all the intended use. They can make a good suggestion then. They suggested one of their 4x4 Extreme (2wd truck) for mine and what little bit I've been able to drive, it has lots of grunt and reasonable idle.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 06-05-2003, 02:10 PM   #5
71Blazer
Goodbye Darlin'
71Blazer's Avatar
Ditto on the Comp Cam 268, works well in my 400 anyway (mucho torque )
1971 Blazer CST SOLD!
71Blazer is offline   Reply With Quote
