Old 08-28-2010, 12:13 AM   #1
gnstalodz
brake light switch - pict request
I have a 72 C10, the brake light switch seems to be jimmy-rigged into place. I was hoping someone has a pict of what it's supposed to look like above the foot pedal. Thanks guys
gnstalodz is offline   Reply With Quote
Old 08-28-2010, 02:25 PM   #2
gnstalodz
Re: brake light switch - pict request
bump
Old 08-28-2010, 04:20 PM   #3
dckdgrs
Auto or man trans?
dckdgrs is offline   Reply With Quote
Old 08-28-2010, 05:20 PM   #4
GruntMoanCough
GruntMoanCough's Avatar
Maybe this will help you out some.......
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 08-28-2010, 09:47 PM   #5
gnstalodz
that pict slightly helps. Thank you.
Its a 4speed manual
Old 08-28-2010, 10:44 PM   #6
GruntMoanCough
This is the best pic I can get from my '68, taken from the left side of the steering column, looking up. Maybe you can make sense of this.
Old 08-29-2010, 06:00 AM   #7
eagleuh1
eagleuh1's Avatar
It should have a plate with a hole in it to mount to. Put the threaded end through, put the nut on and adjust the 2 nuts to where the lights come on when brake depressed, go off when not.
eagleuh1 is offline   Reply With Quote
Old 08-29-2010, 08:31 PM   #8
gnstalodz
ok its the same it appears... But the only problem is my brake pedal. The part that physically hits the switch, seems to be gone... -.-
Old 08-29-2010, 08:31 PM   #9
gnstalodz
ps. thank you for the pict GruntMoanCough
Old 03-25-2012, 10:40 PM   #10
502ms
502ms's Avatar
Trying to figure this out...is there a way to tell the difference on what side the wires go on! I.e. a "+" on either prong?
Asking because I'm finishing up my painless harness install...
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 03-26-2012, 09:06 AM   #11
gcburdic
Restoration Virgin!
gcburdic's Avatar
check this thread for a close up picture...http://67-72chevytrucks.com/vboard/s...d.php?t=516224
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 03-26-2012, 09:09 AM   #12
502ms
502ms's Avatar
Thank you, Geoff!
Best Regards,
Leon M.
Old 06-10-2013, 10:31 AM   #13
DKclassis72
does it matter what wire you hook up the ecm/tcm brake switch leads too? orange or white?
DKclassis72 is offline   Reply With Quote
Old 06-10-2013, 07:49 PM   #14
jocko
jocko's Avatar
No, does not matter which terminal each wire connects to - switch is just a circuit interrupter. Pressing the pedal lets the switch pop open and close the circuit to light the lights.
