07-26-2010, 11:24 PM | #1 |
Weekend Gauge project.
I changed out my volt, oil and temp gauges this weekend, I went with the Sunpro brand, I also installed an RPM gauge.
The truck was running when I took the Pics.
1971 C-10 2004 Yukon: 1998 Honda Accord 2008 Honda Civic 2004 HD V-Rod http://67-72chevytrucks.com/vboard/s...d.php?t=226458 Last edited by JCA1972; 07-26-2010 at 11:25 PM. |
07-26-2010, 11:33 PM | #2 |
Re: Weekend Gauge project.
Looks great! The PO of my truck used the same sun-pro tach and put it in the same place, but he didnt do near as good as job as you.
Keep up the great work! |
07-31-2010, 07:22 PM | #3 |
Ive go the same tack also, Looks slick and fits like it was made to go there, id like more info on your other gauges please.
08-01-2010, 10:08 AM | #4 |
messup up on post
36 master 36 master delux coupe,6cly,3sp. 58 impala,348 3 duces,4 sp. 56 belair,302,4sp,12 bolt. 2000 silverado,5.3 auto. 65 foo foo rd,352 auto,for sale Last edited by kq4pc; 08-01-2010 at 10:13 AM. Reason: messed up |
08-01-2010, 10:10 AM | #5 |
Hey JCA1972 Got a question about pulling the guage bazel.do you have to drop the steering colum to get bazel off?i just picked up a 68 short step side,and po had bought one and never installed. thanks Bobby
36 master 36 master delux coupe,6cly,3sp. 58 impala,348 3 duces,4 sp. 56 belair,302,4sp,12 bolt. 2000 silverado,5.3 auto. 65 foo foo rd,352 auto,for sale |
08-01-2010, 10:20 AM | #6 |
Not to jump in on a question for someone else, but I did have to drop my steering column.
08-01-2010, 10:59 AM | #7 |
PROJECT 7DEUCE
Nice upgrade I just did my lowers with autometers...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
08-01-2010, 11:31 AM | #8 |
Nicely done, I like it!
Things happen for a reason! |
08-01-2010, 02:30 PM | #9 |
Has more rust than truck...
Nope, just the bracket that holds the steering column gromett and then the screws around the benzel. Also need to pull the cable, oil pressure line and unplug the wiring.
08-01-2010, 03:12 PM | #10 |
I'm gonna do that too - how long did it take you? did you re-wire it, or did you use the existing wiring? Looks really nice.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
08-01-2010, 04:22 PM | #11 |
its all about the +6 inches
non tach panels will come out with some work, but loosening the column at the top will help. Tach panels need to be loosened though. I normally remove the nut on one side of the column but not on the other. Drops it enough without flopping it into your lap.
08-29-2010, 11:37 AM | #12 |
I used all the new wires that came with the gauges it was easier than i tought. the hardest part was cuting the holes on the plexi glass, it breaks pretty easy. you can do it in a few hours.
1971 C-10 2004 Yukon: 1998 Honda Accord 2008 Honda Civic 2004 HD V-Rod http://67-72chevytrucks.com/vboard/s...d.php?t=226458 Last edited by JCA1972; 08-29-2010 at 11:39 AM. |
08-29-2010, 11:41 AM | #13 |
You shouldnt have to but it helps if you drop it a little, I had to drop mine because I have my steering coulmn pushed in about 3".
1971 C-10 2004 Yukon: 1998 Honda Accord 2008 Honda Civic 2004 HD V-Rod http://67-72chevytrucks.com/vboard/s...d.php?t=226458 |
