Old 08-29-2010, 06:32 PM   #1
protrash64
Resistance is Futile
protrash64's Avatar
Re: Mad beyond all comprehension
It should be similar to the output shaft on the trans. I say similar because I have seen it written as 'the same as the trans' while others have described the angle as being slightly less(down) because the pinion 'climbs' the ring and causes twist under acceleration and load, therefore adding in the extra degree or so needed to be 'the same'.
Hope this helps, some anyway.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 08-30-2010, 01:01 AM   #2
Captainfab
60-66 Nut
I can get that angle for you tomorrow Zack.
Old 08-30-2010, 08:40 AM   #3
CVA59
Thanks Fab.
Zack
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline   Reply With Quote
Old 08-31-2010, 12:07 AM   #4
Captainfab
60-66 Nut
OK here's what I came up with. With the trailing arm mounts level, the pinion is up 14 degrees.
Old 08-30-2010, 01:10 AM   #5
chevy_mike
Never Ending Projects
chevy_mike's Avatar
That's actully more true with leaf spring rears since the spring will wrap up under acceleration. With trailing arms, you don't get the pinion rotation as the axle is hard mounted to the trailing arms and cannot rotate. This is one reason trailing arms setups hook so well and handle so good (it's what NASCAR uses still). You don't get the loading/unloading as you play with the gas pedal.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
