Steering Wanders
I just had my wheel alignment done after I found the po installed the drag link backwards, the truck tends to wander, not to any paticular side so I am constantly corecting the steering back and forth,not radically but just enough to be a pain, the front end is all new no slop in anything,
the castor is at 2deg 18min left and 2deg 49min right Any ideas ? |
Re: Steering Wanders
You sure it isn't in the steering box? If so it is pretty common for them to get play after a few years. And there is a procedure for adjusting the steering box to remove some play. Just important not to over adjust. That procedure is in the overhaul manual and the Haynes I believe.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
![]() Join Date: May 2009
If the steering box checks out, see if the toe is zero or toed out.
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
Cruzin
check your center link mine was in backward and my truck wandered i installed it correctly, got an alignment and she drives nice now
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
![]() Join Date: Feb 2001
Glad you got her fixed...my truck had a major alignment screw up and it sure does mess up ones drivability of their truck.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
#7 | |
I'm thinking maybe the power steering box |
do you have a front sway bar that limits swaying??
Active Member
![]() Join Date: Jul 2007
First check out the gearbox to make sure it's not the problem.
Then insure all of the steering components are within specs. If all that checks out, have a good, reputable front end shop check the front end again. As GruntMoanCough mentioned above, toe in toe out and caster and camber are very important for tracking on the highway. And don't overlook the possibility of bad tires. Swap them if you have to to test. Also, if you ran the truck for a period of times with the front end out of alignment, you will have uneven wear on the tires. http://www.anewtoronto.com/wheel%20alignment.html |
Hollister Road Co.
I had the same issue with my 72. Replace everthing but the box and it stll wandered. The box check ok but I replaced it anyway and it fixed the problem.
![]() Join Date: Jul 2010
If the PO drove for a while with the alignment and draglink issues, I bet your tires are worn improperly. Try a tire rotation?
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() |
Old Skool Club
![]() Join Date: Jun 2001
An old man I knew was into Model T Fords. He used a VW steering stabilizer (shock absorber-type) to stabilize his T front end.
If all else fails, the 4-wheel and off-roaders also have them available to add to the front ends and that will stop the wandering and sudden movements that a pot hole or other roadway variation that might cause sudden veering.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Check to see that the steering is on center. Drive it & mark the steering wheel to the hub with chalk when it is going straight down the road. Bring it to the shop & line up the marks. Crawl under the front & see if the inner tie rod ends are equal in relation to the frame. If not you need to center them with the tie rod sleeves & reset the toe-in. These trucks drive as good as anything out there when you get them right.
did you check or replace the rag joint very common problem on the trucks
Fuzzy |
#15 | |
Only one problem left !!, The steering wheel won't return to centre, tommorrow I'll disconnect the drag link from the pitman arm and see if I have any tight spots in the ball joints and tie rods and check the steering box for tightness |
#16 |
Active Member
Glad you found the problem. Unevenly worn tires or tires that have thrown a belt, sometimes mimick front end aligment problems. I always recommend swapping tires before doing any major work on the front end unless the problem is fairly obvious.
#17 |
member #16
![]() Join Date: Dec 1999
Make sure the adj. screw on the gearbox isnt too tight. That will cause not to return to center.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
#18 |
Glad all of us could help!
#19 | |
While the steering gear was all disconnected I checked the steering box for true centre, I got 4 1/4 turns lock to lock so I put some masking tape on the column and some on the hub and marked it at 2 1/8 turns which is true centre, I then put all the steering linkages back on and sat it on the ground lining the marks up on the steering column and the wheels are turning to the right slightly so it's back of to the alignment shop next week and hopefully all solved |
#20 |
I looked at the center link on my 72 and it looks like it will only go in one way. The attaching location holes of the pitman arm and idler arm angle forward. If were in backwards it seems the link would be rubbing the tierod. Does anyone have pics of correctly or incorrectly installed center link? I checked the chilton's and no diagrams for center link placement.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#21 | |
#22 |
Thanks for the shout back, That's what mine looks like. Guess maybe the steering gear is too lose.
