Old 08-30-2010, 02:15 PM   #1
dman1982
dman1982's Avatar
radio memory????
ive got a 84 k10, i just put a radio in it not too long ago..sounds awesome...but i dont have any memory on it....now its starting to bother me...does anyone know what i have to do to get it to work? if you could break it down barney style that would be awesome thanks
dman1982 is offline   Reply With Quote
Old 08-30-2010, 02:24 PM   #2
bucannon
Salty Sailor
bucannon's Avatar
Re: radio memory????
your red and yellow power wires are switched.
86 c-10 Custom Deluxe
Savannah, Georgia
bucannon is offline   Reply With Quote
Old 08-30-2010, 02:26 PM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
Well, you're running an aftermarket radio no doubt, because a factory deck would not have any sort of memory, not until 1990 in the square bodies at least.
There is a radio forum here, it's down below, lots of good info on it. Sounds like you just need to find the constant hot wire, and wire it up to the battery or a constant hot in your fuse block.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 08-30-2010, 02:31 PM   #4
bucannon
Salty Sailor
bucannon's Avatar
yea, preferably the fuse block. striaght to the battery in "barney terms" willend up smokey most likley haha
Savannah, Georgia
Old 08-30-2010, 02:36 PM   #5
dman1982
dman1982's Avatar
is there a constant hot spot in my fuse box?
Old 08-30-2010, 02:36 PM   #6
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
check with a test light and key OFF to find a constant fuse, then use a terminal tap from there. Any autoparts store should have it.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 08-30-2010, 02:40 PM   #7
dman1982
dman1982's Avatar
i have a fuse like this..i bought it when i was putting the radio in...which spot in the fuse box is the constant one??? or do i have to make one?
Old 08-30-2010, 02:44 PM   #8
RandyP
RandyP's Avatar
Should be a spot that says BATT and you can plug in a spade type connection, like a single side of a blade fuse. You'll want to be sure to put a fuse in the line if you use that connection. Otherwise, do as they said. Take a test light and find a hot fuse while the truck is not running. Should be a few of them in there to make a choice from, I'd find a nice 20 fuse to hook in to.
Old 08-30-2010, 02:45 PM   #9
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
have you checked the owners manual on how to set stations to memory? that could be the problem or possibly installation.. or even both.
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 08-30-2010, 02:49 PM   #10
Walts_restoration
First thing id do is invest in a test light and learn how one works. 5 bucks i think and one of the simplest electrical tools you'll ever need.
I used the left side of the horn fuse. I'm pretty sure that's the "power" side, but i cant remember if i tested it or not. Make sure before you put alot of power through it or you may blow the horn fuse.
Old 08-30-2010, 02:49 PM   #11
dman1982
dman1982's Avatar
it doesnt have any memory....so installation...lol...im not paying the guys at best buy a hundred bucks to hook up a radio....then again...it would have memory...lol...but i can figure that out...i will go under there in bit and check it out. thanks
Old 08-30-2010, 02:50 PM   #12
dman1982
dman1982's Avatar
thanks walt...the horn dont work right now any how lol
Old 08-30-2010, 03:23 PM   #13
Walts_restoration
Look where the needle of my test light is pointed. This is where you want the fuse tap to end up.
This is how the tap goes around the fuse.
Fuse inserted with tap.
I remember my first radio install. Didnt install it right and blew a cluster light fuse. Never told dad and drove for two days without cluster lights. Just wait till you get to the fun on an amplifier install! haha
Old 08-30-2010, 04:18 PM   #14
dman1982
dman1982's Avatar
hey thanks walt...thats the barney style i was talking about lol...dumb marine here haha
Old 08-30-2010, 04:33 PM   #15
Walts_restoration
Not really dumb if its the first time you've seen it. I did my first radio install 5 times at least, and each time i did it differently and improved it. Heck, my first speaker install i had 4 speakers running off the stock am/fm radio in my 77 from the single front speaker line! so one positive and one negative for 4 speakers!
The great don't become great by doing things right the first time. You will fail many times before you get it right, and its simply called experience.
Old 08-30-2010, 04:36 PM   #16
dman1982
dman1982's Avatar
its only my first install on this truck...ive done them before but it was a long time ago.
Old 08-30-2010, 06:28 PM   #17
dman1982
dman1982's Avatar
hey walt...thanks...my memory is now working...thanks alot...now i can actually program my radio...store stations..hook up my mic...etc...thanks a bunch
Old 08-30-2010, 11:37 PM   #18
Walts_restoration
no problem man. I had to double check myself to make sure i installed it right when i put mine in haha. I still gotta finish my behind cab and amp mount off.
