T-case adapter needed
Does any one know what is needed to adapt a '02 2wd 4L60E to a '86 K5 np208?
Thanks, Garvin |
Re: T-case adapter needed
wow, that's a different request...
You might have an easier time with a divorced transfer case....
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
What would I add to the in-put side of the T-case to connect to the tranny?
Thanks, Garvin |
http://advanceadapters.com/product/2322/50-0405.html
there are alot of people doing this swap is what I found from a quick google search.... this is the adaptor needed by AA but I read somewhere there is a stock one too that is way cheaper and will work. ![]() Chevy 700R4/4L60E-NP208/NP241 adapter $50 http://www.backwoodsparts.com/Transfercase.html
J.T. 1972 SWB 4X4 on 35"s with 6" lift all around 3/4 ton running gear with high steer and 4.88s 350/th350. SOON TO BE DONE:2" higher in front 37"s,LSX Swap,Hugger Orange & White Paint Scheme,Air Conditioning,Power Windows & Locks,Complete Gauge Kit,Tank Relocation,Double Din Nav with full Audio System. My Build Thread http://67-72chevytrucks.com/vboard/s...=1#post4169140 Last edited by SWB4x4; 08-29-2010 at 02:08 PM. Reason: found other adaptor |
Won't he still need to swap output shafts in the transmission since it's a 2wd?
measure and check once you pull the tailshaft off and put the adaptor/tcase on you need to see how much spline engagement you have.
I will be running a 2wd 4l80e with my np205 using a fig8 th400 adaptor.
J.T. 1972 SWB 4X4 on 35"s with 6" lift all around 3/4 ton running gear with high steer and 4.88s 350/th350. SOON TO BE DONE:2" higher in front 37"s,LSX Swap,Hugger Orange & White Paint Scheme,Air Conditioning,Power Windows & Locks,Complete Gauge Kit,Tank Relocation,Double Din Nav with full Audio System. My Build Thread http://67-72chevytrucks.com/vboard/s...=1#post4169140 Last edited by SWB4x4; 08-29-2010 at 09:53 PM. |
#7 | |
This adapter is for a Pre-'97 4l603. The '02 model that I have has a 6 bolt tail shaft. |
Any one know if the 6 bolt th400 adapter will fit on the 6 bolt 4l60e?
Never mind TH400 is also a 4 bolt. Any info on turning a 208 in to a divorced setup?
I want to use what I have for now.
![]() Join Date: Mar 2003
Turbo 400 is 6 bolt
Th400 is 6 bolt but the pattern is smaller than the 4L60E. You can't really get around using the AA kit. There is a special adapter that goes from the 4L60E 6 bolt down to the 4 bolt that has a spot to screw the VSS (Vehicle Speed Sensor) into it and includes a reluctor ring that clamps to the tail shaft. Then, since the shaft is longer they include a 1 and 1/2" 4 bolt spacer that also goes after this adapter, so it ends up being a crazy 3 adapter setup when you include the one on the T-case. I was going to put a 205 behind my 4L65E and this is what I had to do.
1964 C10 Shortened Shortbed Cammed LQ9 P&P 1967 C10 Trophy Truck BB 438 (soon to be worked on again) |
Is the VSS threaded or is it set up like a crank/cam sensor for a LSX? I might try and fab an adapter with a VSS when I get back to the states. Is the shaft free floating between the tranny and T-case? Are there any bearings or seals on the any of the adapters?
#15 |
skoffice
A '67 TT would be interesting to see. What kind of suspension setup are you planning on running in the front? |
#16 |
The VSS is threaded so you can set the clearance from the reluctor ring (I think about .010") but it is a similar style magnetic pickup sensor. The adapter has two holes in it so you can go on either the left or right side, and includes a pipe plug for the unused hole. You could probably fab one up pretty easily if you have access to a mill and/or lathe. If you built the expensive part of the adapter you can buy that 4 bolt spacer seperately for like $70 or something like that.
That truck is kind of on the back burner right now unfortunately because of the '64. I need to finish the '64 so I can have something reliable to drive back and forth up to the shop that has the '67 since he moved further away haha. I plan on doing all custom honey combed A-Arms up front, custom spindles and probably Desert Specialties hubs. Out back standard 4 link with a custom 14 bolt with 40 spline shafts. I'm going to use the stock boxed and gusseted frame rails and tube out in between and into the engine compartment up on into the cab.
#17 |
No mill, but I do have a TIG. Shouldn't be too hard to find some one local for the mill work.
Sounds like a good plan for the '67. Does any one make glass flairs for that body style?
'72 C-10 LWB LS1/4L60E |
#18 |
Nobody manufactures them but there was a guy a few years back on this site that was making them from scratch for a while. I don't know if he still does but they looked really good. Ya if you have a machine shop near by they should definitely be able to figure something out. If you have access to AutoCAD draw something up and see if they can CNC it.
#19 |
Wasn't the np241 used behind the 4l60e with the six bolt tail housing? Just bolt the 208 to the stock 241 adapter for that tranny. The output shaft would need trimmed down I'm guessing, since it's a 2wd unit.
-Andy '77 K5 Blazer '78 K10 Shortbed '78 C20 Suburban '79 K30 Crew Cab Dually '84 C10 Short Stepside '88 K20 Suburban ![]() |
