Old 08-30-2010, 09:29 PM   #1
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
Re: Trans vs rear end
[QUOTE=Indian113;4165438 I found a 700r4 with 2 year warranty and shift kit installed for $1295.00 I think trans will be most cost effective even with having to shorten driveshaft and buying new floor shifter[/QUOTE]
does the cost include a new torque converter? also, you need some way to control the lock-up, but there are simple cost effective ways to do that.
Larry
fleetsidelarry is offline   Reply With Quote
Old 08-30-2010, 11:43 PM   #2
apachedaddy
apachedaddy's Avatar
Thats why I said around 2 grand for the trans route. There are little things that add up quick to do the full install.
I did all my shopping through "Bowtie Overdrive"
175 = Converter
160 = TV cable system
100 = Lock up kit
70 = Speedo kit
38 = converter cover
50= flex plate
35= dip stick
1095 = Stage one trans
1295 = Stage two trans
They also havs a trans cross member for 175, its built so you dont have to do any mods to the e-brake cable.
There are other places that have kits like "Monster trans" for right at 1900 but you still need a flex plate.
There is also the drive shaft factor and thats around 300 to have one built and shipped.
There is allways the craigs list or P-N-P route that i'll look into once I'm home but I'm one that says you get what you Pay for in the long run.
66 short wide fleet sbw = Gave to my best friend
66 short wide fleet bbw
apachedaddy is offline   Reply With Quote
