Old 08-31-2010, 08:15 PM   #1
3r!c84
Badass
3r!c84's Avatar
upgrade ? 10 bolt
sorryy for the typo!!!! ^^^
im putting in a 400sbc in place of my 305.
around 400 ponys
you think i should upgrade and get a 12bolt instead of my 10bolt i have now?
10bolt=3.42 gears. i could get a posi for it.
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 08-31-2010, 08:25 PM   #2
nbpro
Re: upgrade ? 10bold
If you do swap out to the 12 bolt, send me the 10 bolt. lol I guess it would depend on what you're actually going to do with the truck. Crusing, drag strip, park it in a garage and wash it on the weekends.
nbpro is offline   Reply With Quote
Old 08-31-2010, 08:26 PM   #3
3r!c84
Badass
3r!c84's Avatar
Originally Posted by nbpro View Post
10 bolt gears ?
3:42
-00 Saturn 5spd
1/4:13:90
Old 08-31-2010, 08:31 PM   #4
nbpro
edited
Old 08-31-2010, 08:32 PM   #5
3r!c84
Badass
3r!c84's Avatar
driven hard and put away wet
-00 Saturn 5spd
1/4:13:90
Old 08-31-2010, 08:40 PM   #6
ont_guy_38
ont_guy_38's Avatar
Well I have had countless 10 bolts in my life and only one 12 bolt and guess which one ever broke on me
ont_guy_38 is offline   Reply With Quote
Old 08-31-2010, 08:46 PM   #7
nbpro
get a posi for it. 3:73 gears
Old 08-31-2010, 09:39 PM   #8
Wild83C10
Wild83C10's Avatar
Never had a problem (besides some leaks) with my 10 bolt with posi and a 5 speed, stock axles. I put down about 500 whp for now.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 08-31-2010, 10:09 PM   #9
SBTork
Garage wrench
SBTork's Avatar
from what i've heard, not based off personal experience. The 12 bolt is not much better or stronger than a 10 bolt, at least this body style truck 12 bolt. I think the 10 bolt axles can be made strong for not much money.
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 08-31-2010, 10:16 PM   #10
3r!c84
Badass
3r!c84's Avatar
Re: upgrade ? 10 bolt
ok just checking..also would all the drum brake parts off of a 10bolt fit on a 12bolt?
-00 Saturn 5spd
1/4:13:90
Old 09-01-2010, 11:24 AM   #11
83burban
I have been contemplating this swap as well. I plan on dropping a healthy big block in down the road, but wanted to upgrade everything else before I go that route.
SB Tork - I would have to disagree. The 12 bolt will befnitely be stronger than a 10 bolt in stock form, the ring gear is larger IIRC and the axles might even have more splines.
If you are just cruising and daily driving then the 10 bolt will be more than adequate for daily use. Putting slicks and power-adders would require a rear end swap for reliability or beefing up your current rear.
Hope this helps
83burban is offline   Reply With Quote
Old 09-01-2010, 12:03 PM   #12
Keith Seymore
Keith Seymore's Avatar
I've had the same 8.5" ring gear 10 bolt axle in my 3900 lb race car for 32 years.
I'd stay with the 10 bolt.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-01-2010, 05:05 PM   #13
HOGDADDY
HOGDADDY's Avatar
The 12 bolt pinion gear is smaller than a 10 bolt pinion gear fwiw.
HOGDADDY is offline   Reply With Quote
Old 09-01-2010, 08:04 PM   #14
3r!c84
Badass
3r!c84's Avatar
so the 12 bolt is weaker?
-00 Saturn 5spd
1/4:13:90
Old 09-01-2010, 08:16 PM   #15
wyattglock
wyattglock's Avatar
If you have your heart set on swapping rear ends, I would go with a 14 bolt that has the disc brake conversion on it. That would save the weight of the drums, but is a lot stronger than the 10 or 12 bolt. However, it is still heavier than a 10 bolt.
wyattglock is offline   Reply With Quote
Old 09-01-2010, 08:17 PM   #16
3r!c84
Badass
3r!c84's Avatar
going to keep it till or if it breaks
-00 Saturn 5spd
1/4:13:90
Old 09-01-2010, 09:17 PM   #17
N2TRUX
Happy to be here
N2TRUX's Avatar
It could be considered if you have enough torque to create flex. The solution would be to run a rear end girdle. Look here- LINK
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-01-2010, 09:25 PM   #18
3r!c84
Badass
3r!c84's Avatar
yea thats a good idea too ..
-00 Saturn 5spd
1/4:13:90
Old 09-01-2010, 09:58 PM   #19
78 Chevyrado
At a bare minimum, put NEW spider gears in it. The spider gears broke in my 87's 10 bolt after i put a 400 in it, and when it broke it twisted the driveshaft a bit and took out a brand new transmission that i had and i had to just eat the cost. I put new spider gears in the replacement 10 bolt (junkyard) and never had another problem. BTW I was only giving it maybe 1/2 throttle when it broke, BUT I had been doing burnouts all over the place for a week previously...
What happened was the spiders broke and the engine revved way up real quick and then a piece of the spider gear got into the ring gear and stopped the trans instantly. BOOM no more 1st, or reverse. don't know about 2nd and 3rd, couldn't get to them...
78 Chevyrado is offline   Reply With Quote
Old 09-01-2010, 09:59 PM   #20
3r!c84
Badass
3r!c84's Avatar
im going to a posi
-00 Saturn 5spd
1/4:13:90
Old 09-01-2010, 10:02 PM   #21
78 Chevyrado
Might check out powertrax. no clutches to burn out or expensive synthetic oil to buy. and you don't have to tear down the differential.
Old 09-01-2010, 10:11 PM   #22
3r!c84
Badass
3r!c84's Avatar
is that a locker?
-00 Saturn 5spd
1/4:13:90
Old 09-01-2010, 10:43 PM   #23
355bullet
355bullet's Avatar
stay with the 10 bolt, posi and 3:73's
i have that and it does fine
But if u change it to a 12 bolt your going to need a longer drive shaft
355bullet is offline   Reply With Quote
Old 09-01-2010, 10:45 PM   #24
3r!c84
Badass
3r!c84's Avatar
i dont know about 3.73 gears i have 3.42s right now that was a big step from the 2.7somthing it had before
it humms at 3k going 70ish down the highway with 28in tires
-00 Saturn 5spd
1/4:13:90
Old 09-02-2010, 02:28 AM   #25
355bullet
355bullet's Avatar
3.73 is still a highway gear, if u have a 700r even better.
Both my trucks have 33's. one with the 12 the other 10bolt
i stuck a nice auburn posi in the 12bolt
