08-31-2010, 01:13 PM | #1 |
63-66 front frame width..
Can someone tell me the width of the frame where the front cross member is?
I won't be near my truck for a while and have an idea for front suspension. Instead of doing a Mustang 2 front, I'm thinking about seeing if I can get a 4th gen F-body K-member to work. I can get on for free from a friend. If I can make it work, the plan is to buy a tubular one and shave a good amount of weight and get much better front end geometry. Shaun
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
08-31-2010, 11:25 PM | #2 |
60-66 Nut
Re: 63-66 front frame width..
I can get that for you tomorrow.
09-01-2010, 11:20 PM | #3 |
60-66 Nut
Ok, here's the measurement. Since the frame rails aren't parallel thru the engine compartment, I measured as close as possible to the centerline of the upper balljoints. At that point the frame measures 29 1/4" wide.
