09-01-2010, 08:41 PM | #1 |
How too mount the alt brackets to the exhaust
Just received these from southern parts from his parted 68 V8. I can't figure out how the angled bracket mounts to the exhaust thread boss's. It just doesn't seem to fit in any why I try. I assumed 67/68 were the same and mounted the same. Most pics I find the alt is covereing up the lower bracket. Any insight would be apprecated. Many I have the wrong ones but Southern did say they mounted to the exhaust :-( I know I will feel stupid if they really do fit and I just couldn't figure it out. |
09-01-2010, 08:57 PM | #2 |
Re: How too mount the alt brackets to the exhaust
Does your exhaust look like this one?
09-01-2010, 09:09 PM | #3 |
What?
Here is how mine are.
1968 truck ram exhaust manifold. The lower bracket you have is what I have, but those uppers you may have trouble with (Not enough arch). Check my last pic.
Chris 1968 K20 Suburban 1972 K10 LWB PU Last edited by vectorit; 09-01-2010 at 09:13 PM. |
09-01-2010, 09:39 PM | #4 |
Indyuke, yes my exhaust looks like yours. My brackets look nothing like the one attached to your manifold. Maybe I have the wrong one.
09-01-2010, 09:40 PM | #5 |
victorit, so the long piece goes under the top mount. Let me see if that works. out to the garage I go,
09-01-2010, 09:49 PM | #6 |
Looks like I have the wrong set. Indyuke, is that exhaust/bracket off a 67?
09-02-2010, 09:43 AM | #7 |
Looks like the upper style that you have, are the ones that bolt to the intake. They often stack 2 together, to make them more rigid. Give that a try.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
09-02-2010, 10:53 AM | #8 |
One foot in front of the other
I believe the brackets you have are not used for the exhaust manifold that Indyuke posted. They use a different type manifold boss.
09-02-2010, 11:15 AM | #9 |
So my next question is are the manifolds with the threads pointing out correct for a 67 or are the ones pointing forward? If I understand which manifold is correct I can find that years alt brackets. Thanks for aLL THE HELP SO FAR guys!!!!
09-02-2010, 01:16 PM | #10 |
I was under the impression that what DPowers and Vectorit has was used for the 67-68 283 and 327 are correct... take a look at this site: http://www.am-autoparts.com/AM/Exhau...-/AM-28014528/
The style I have was used more often in the early to mid-60's trucks and in most corvettes. If you have the same setup I have, then you should only need the angled pieces to secure the top of the alt. by bolting it to the intake manifold like DPowers last pic shows. Can you post a pic of the exhaust manifold that's on the truck? Last edited by Indyuke; 09-02-2010 at 01:29 PM. |
09-02-2010, 01:46 PM | #11 |
Its the same as what Indyuke posted. Thanks for your time, I apprecate.
09-02-2010, 10:34 PM | #12 |
My pic was from my '66
