Old 08-24-2010, 11:43 AM   #1
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
WHich Booster fits??
well Im tire of waiting??? looks like I need to hit the bone yard for a booster
So which ones fit on our brackets and peddle assemblies ??? I'm looking to see if theres something newer that I might find local??
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 08-24-2010, 02:49 PM   #2
splehigh
splehigh's Avatar
Re: WHich Booster fits??
I'm interested in this as well. Looking to upgrade my 71 to PB. Then maybe my wife won't be afraid to drive it. lol
splehigh is offline   Reply With Quote
Old 08-24-2010, 02:53 PM   #3
Todd Hepler
Rottenwood Garage Member
Todd Hepler's Avatar
I used the bracket and booster off of a mid 70's C10.
The actuator rod was not the right length on both the original non power brakes and the 70's c10 set up. It was an easy fix
Cost me around $20 at the u pull it here in atlanta.
Todd
Todd Hepler is offline   Reply With Quote
Old 08-24-2010, 03:05 PM   #4
68 TT
Still plays with trucks
68 TT's Avatar
Todd
I just did the same thing but used an 80's vintage square body booster on my 67 K10.
Only had to drill two additional holes in the booster mount bracket to make it fit. The other two holes matched up and put the center of the booster into the stock cab opening.
The actuator rod was a two piece design that is threaded in the middle. It could have been cut down and drilled out & re-threaded to the right length but I chose to put a larger brake pedal on mine as it had the tiny manual trans size brake pedal so I just put the larger pedal where it need to be to line up and welded it in place just like stock. The pedal placement is in the exact same location as stock and it now says disc brakes on the pedal pad too.
A little bit of the booster mount bracket can be trimmed off to make it look better and clear the steering column anchor bracket.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 08-24-2010, 03:13 PM   #5
Hottrucks
Hottrucks's Avatar
I have power brakes...well kinda...what happen is I bought a used set up and the booster was bad...so I have the hardware and peddle stuff in just looking for a replacement BOOSTER that I can drop in??
Old 08-24-2010, 03:14 PM   #6
Todd Hepler
68TT - thats exactly what I have. Musta been an 80's truck I pulled from?
One thing - the booster body is awful close to the automatic trans shifter linkage on the column. I'm not sure how well it would fit with a 3spd column.
Good luck!
Old 08-24-2010, 04:10 PM   #7
68 TT
68 TT's Avatar
Good luck!
I have one from a 70's vintage truck too and the only physical difference I can see is that the older one is cad plated.
I will lower the column a little to clear the linkage if needed or revise the shifter linkage coming out of the column. We will see when I get the column installed.
Old 08-24-2010, 04:17 PM   #8
68 TT
68 TT's Avatar
I have one that I found in a 72 Suburban that I had on the 67 truck before. I think a 80's & early 90's S10 Blazer booster can be made to fit with a little modification. I have a bad one off my 95 S10 Blazer sitting around that looks like it will work.
It is bolted on to the firewall in the S10 Blazer with a four bolt pattern just a little wider than the 67-72 part uses. I didn't modify mine yet to make it fit to see what is needed as far as the connection of the Blazer booster rod to the earlier bell crank assembly. Doesn't look too far off. Most likely just a little cut & weld job will do the trick.
All the other ones I can think of are welded / riveted to a mount bracket of some kind.
Old 08-24-2010, 09:33 PM   #9
johndawelder
johndawelder's Avatar
I used a booster out of an S-10 on my 67.I choose it because I needed the clearance to get the valve cover off of the 427 BB.
johndawelder is offline   Reply With Quote
Old 08-24-2010, 09:49 PM   #10
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I have a booster from 72 in mine..
I assume you dont wanna hear 'go buy one from autozone for 110$' lol hottrucks...
Idk good luck interesting thread
John
1999 Toyota Tacoma 4x4
Old 08-24-2010, 11:09 PM   #11
68 TT
68 TT's Avatar
I like the $7 at the pull it yourself wrecking yard much better
There are at least a dozen square bodies all with power brakes at all times there but a 67 to 72 with power brakes is a very rare find. I have only see one in five years. I snagged that one as soon as I saw it.
There are even more S10's than square bodies so that option is even better if you have an old 67-72 booster system to mod.
Once you make the mods to the 67-72 booster mechanism to fit the S10 booster then spare parts are a dime a dozen.
Old 08-24-2010, 11:16 PM   #12
68 TT
68 TT's Avatar
Do you have any pics of this?
Did you use the one that bolts directly to the firewall or one with a mount bracket that stands off the firewall a bit?
Old 09-03-2010, 04:57 PM   #13
treveiger
treveiger's Avatar
I pulled a brake booster set up off a 70-72 gmc. how can i tell if it works??
treveiger is offline   Reply With Quote
Old 09-03-2010, 05:25 PM   #14
68 TT
68 TT's Avatar
You can hook up a vacuum source to the booster inlet port and see if it holds a vacuum. Other than that you really need to put it on to see if it fails under pedal pressure.
I have had a couple that held a vacuum until the pedal was pressed then they dumped all the vacuum and did not work to slow the car down. Pedal just went to the floor with no effect.
