09-01-2010, 10:14 PM | #1 |
Old member
New Power steering
OK,
this thread addresses some issues with brackets and such for differant years. http://67-72chevytrucks.com/vboard/s...d.php?t=419306 I have the stock 71 power steering. I want to know what I would need to change it over to a later model with better feel. Is the price differance worth the swap also. O-riley auto parts has the factory 71 stuff. Is a 73 up cheaper you think? I guess I need to check on it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-02-2010, 06:27 PM | #2 |
Old member
Re: New Power steering
No one can tell me they haven't changed to a newer sector!
09-02-2010, 07:19 PM | #3 |
I believe the 77-78 steering boxes have the same hose fittings as ours do and they are variable ratio as well.
09-02-2010, 07:54 PM | #4 |
Old member
Thanks, are they direct replacements? I don't mind the steering now but if the money is basicley the same and I can get a better sector I think it would be worth it. Mine is going to need replacing very soon as in the next couple of weeks so I may check on it. Thanks again.
09-02-2010, 08:50 PM | #5 |
Yes, they are a direct bolt in.
09-02-2010, 10:10 PM | #6 |
Old member
Cool I have to check on it, thanks!
09-03-2010, 07:08 PM | #7 |
I swapped my Steering Gear for one out of an '85 and it was a direct bolt up. I also pulled and used the pump and hoses. The pump sets high in the engine bay unlike the old style. I had a leaky pump and hoses so it worked for me. The Variable assist made a HUGE difference in how my truck drives. I pulled all of these parts used for $47.00
