Active Member
Re: big block owners WTF?
Are you running an Edelbrock carb? I bet you are, if so, change it to Holley.
1972 K5 Blazer ALL ORIGINAL paint & engine, A/C, Tilt, 4sp, AM/FM, Tow Hooks, Aux Battery Tray, Tach, Vacuum 2004 FORD FX4 SuperCrew 2005 CTS-V 12 sec family car ![]() 2008 Buick Enclave AWD, Nav, & DVD, Wife LOVES it! Last edited by 72Levi; 09-03-2010 at 10:41 PM. |
Not too sure if this would help your situation but I installed some fiberglass header wrap on my headers and it significantly lowered the under hood temp with my 454.
Hollister Road Co.
Man of Mini-Talents
I'll bite - why would that make a difference? Too lean?
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
My Carbon Footprint
No.....because Holley's rule!
![]() Weird! I have two BBC's that run cool as a cucumber. Never over 190*. I'm sure you have checked this but are you sure your fans are wired to spin the right direction for the way they are mounted (push vs pull)??? |
![]() Join Date: Feb 2010
Check your timing, and dist. for advance. Too far retarded will heat way up.
