Old 08-27-2010, 10:26 PM   #1
extd56
extd56's Avatar
Got a new Suburban today
I saw a Suburban for sale local and went and looked at it. Not sure what I am going to do with it now that I have bought it, I will probably just sell it to someone that would like an original Suburban. I guess I could have Kevin make it a crew cab, he loves to cut in good metal. It is a pretty loaded Suburban, front and rear air, tilt, tach, 350 with a 350 trans. The same guy has owned it since 1987. What do you guys think it would be a good price to ask for it?
extd56 is offline   Reply With Quote
Old 08-27-2010, 10:29 PM   #2
extd56
extd56's Avatar
Re: Got a new Suburban today
It really looks better in the pictures than it does in real life. There is a spot of cancer that someone tried to fix behind the right rear wheel and the liftgate has some cancer and of course under the battery box has some too. The PO has recently installed new drums and brakes on the rear end, new battery, new master cylinder. It runs really good and drives down the road great. It still has the California smog on it and the smog pump is not frozen but the belt was removed at one time. I know from the Po that he rerouted the heater hoses because he thought that the heater core was leaking and the air conditioning was working last year but now blows hot. It also has an older Edelbrock carb on it. I think all the options on the SPID are still on the truck right now.
Old 08-27-2010, 10:33 PM   #3
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice score! I'm not sure what it is worth. But in our area people would ask atleast 5k just because of the options and clean body I'm guessing.
Ryan
1969 Chevy milk truck
Old 08-27-2010, 10:38 PM   #4
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Very nice.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 08-28-2010, 11:36 AM   #5
RCbowtie69
RCbowtie69's Avatar
NICE
RCbowtie69 is offline   Reply With Quote
Old 08-28-2010, 12:38 PM   #6
VA72C10
VA72C10
VA72C10's Avatar
Not sure on value either but I do think it would go up exponentially if you took off the running boards Very cool original burb!
Old 08-28-2010, 12:48 PM   #7
Hart_Rod
Hart_Rod's Avatar
Sweet burb! I'll take it off your hands for $1500...........
Hart_Rod is offline   Reply With Quote
Old 08-28-2010, 07:29 PM   #8
extd56
extd56's Avatar
I think it would be missing a few parts off it and maybe Kevin would have it making a crew cab out of it. You know he loves cutting up these Suburbans.
Old 08-28-2010, 07:51 PM   #9
BlackTopMotors
Is it a 71 or 72 3/4 ton? Does the rear air work...?
I would probably try to get it for around seven depending on what works, rust ...the usual and also if it was going to be a keeper versus reselling...
Looks great!!! Nice Find!!!
BlackTopMotors is offline   Reply With Quote
Old 08-28-2010, 07:55 PM   #10
extd56
extd56's Avatar
I won't be keeping it too long, found something else that I like better at the Good guys show in Pleasnaton today and my wife says my toy box is way too full, I only have about 12 cars and trucks, mostly trucks. The Suburban is a 72 3/4 ton and the rear air comes on but hot air just like the front air does.
Old 08-28-2010, 08:24 PM   #11
Hart_Rod
Hart_Rod's Avatar
Originally Posted by extd56 View Post
I won't be keeping it too long, found something else that I like better at the Good guys show in Pleasnaton today.
No keeping secrets. Whadya find?
Old 08-28-2010, 08:45 PM   #12
extd56
extd56's Avatar
I was looking at a 54 4 door wagon, really cool
Here are some pictures of the bad areas on the Suburban.
There was some rust that was kinda covered up by the right rear quarter behind the tire, some rust in the liftgate as seen in the pictures, some damage on the drivers door from the mirror, and a dent in the left front fender. There is also some rust under the battery box, go figure.
Old 08-28-2010, 08:49 PM   #13
extd56
extd56's Avatar
Here are the pictures of the seats, the rear seatbelts do not match the rest of the belts. The other pictures I guess were when they used to haul a canoe on the top of the Suburban.
Old 08-28-2010, 08:52 PM   #14
extd56
extd56's Avatar
The drivers side front door panel is broken but I do have a complete white set on Ebay right now, I guess I should pull them. The rockers look to be in good condition. Also the steering wheel is junk, big crack in it.
Old 08-31-2010, 06:42 PM   #15
extd56
extd56's Avatar
This is the 54 handyman that I bought yeasterday, has been sitting for a long time. Now I get to play with it.
Old 08-31-2010, 07:06 PM   #16
VA72C10
VA72C10
VA72C10's Avatar
very cool! Love it! I am a big fan of big trucks and wagons!!! You've got them covered now
Old 08-31-2010, 07:44 PM   #17
BlackTopMotors
Still has good potential. Nice 54 (a Bel Air Townsman, Two Ten Handyman or One Fifty Handyman?)
Old 08-31-2010, 08:33 PM   #18
extd56
extd56's Avatar
It is a 150 Handyman but someone has put a 327 engine in it with a 350 trans and a 10 bolt rear end. It has also been converted to 12 volt with an alternator. I am still checking it out. love new toys and good surprises.
Old 08-31-2010, 08:51 PM   #19
Dieselwrencher
Another very cool score! Congrats!
Ryan
Old 09-01-2010, 11:29 PM   #20
mosesburb
I had a V-8
mosesburb's Avatar
I like that thing!! I never cared much for the '54 sedans, but I really like the wagons!!
Nice score!!
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 09-01-2010, 11:44 PM   #21
extd56
extd56's Avatar
Nice score!!
I do not like the sedans either but this ones grows on me. It was stored for a long time I was told but know it is time to get it moving again.
Old 09-04-2010, 09:28 PM   #22
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Loving that wagon those are soooo cool... The sub is daily driver looking but damn I hate ochra...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
