PROJECT 7DEUCE
![]() Join Date: Dec 2002
Tranny cooler question.
Should I mount this cooler to the inside or outside of the frame rail like streetrodders do or should I find another place. Its made from aluminum so id guess it would dissapate heat pretty good all on its own..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Re: Tranny cooler question.
Here is a pict of where we mounted mine...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
the better the airflow the more efficently it works
Active Member
Mount it to the inside frame rail on the outside it will be hit by debris from the tires and your tranny lines run on the inside of the frame rails as well
Just an FYI - if you intention is for that cooler to be used in a HD towing or high stall apllication you may want to rethink your options - a plate and frame cooler will do a much better job
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
PROJECT 7DEUCE
Nope no towin in mind truck will be street driven and only haul itself around.
That's right, it's Copper!!
I mounted mine up front under the truck.
Tom: ![]() 1968 Chevy SWB ZZ383 W/700R4 Gen-II Compact Vintage Air System PPG paint, Mandarin Copper and Vanilla Shake. http://www.hubgarage.com/mygarage/fastom Stupid should hurt and eventually become fatal! |
Moderator
![]() Join Date: May 2007
Are you running the cooler in addition to the stock heat exchanger in the radiator, or just the cooler itself?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 09-05-2010 at 10:30 AM. |
![]() Join Date: Apr 2005
I'm curious also. Does anyone have a part number for any of those coolers?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
PROJECT 7DEUCE
Rob I dont have a part number as I bought 2 of them at hout august nights from a vendor there.. I do have one mounted on my v-8 powdered yota and it seems to always be pretty cool to the touch but its mounted right out front near the radiator. I was wanting to hide this one under my 72 on the inside frame rail just pass the cab.
One foot in front of the other
![]() Join Date: Aug 2008
I bought mine at a swap meet last year- $30. But I think that Summit and Jeg's both carry them. I am using mine as an addition on my '66 and mounted it behind the bumper as well.
