Old 09-05-2010, 04:16 PM   #1
guyryan100
guyryan100's Avatar
Any ideas why carb isn't letting gas through?
Hey guys, any ideas?
The truck ran fine 3 weeks ago when I parked it, today it won't fire up. If I drip gas into the carb it will fire up fine, but otherwise, no luck. It's like fuel isn't getting through the carb (Edlebrok 1406). Gas supply is fine - I disconnected the fuel line and put it in a can, turned the engine over and the can has gas in it. And when I loosen the clamp fuel supply line from the side of the carb it wants to spray out gas, so seems there's plenty of pressure. Anything I should be inspecting on the carb? Everything's pretty new on the truck - gas lines, filter, fuel pump, tank, even the gas is only about 3 weeks old. And again, seems like gas is flowing.
I replaced the ignition wires (from stock Delco to Taylor) so I would expect I messed that up but again, if I drip gas through the top of the carb the engine fires up and sounds normal for a few seconds till the gas runs out.
What is most likely to prevent fuel flow in the carb? Any ideas?
guyryan100 is offline   Reply With Quote
Old 09-05-2010, 04:35 PM   #2
cdowns
cdowns's Avatar
Re: Any ideas why carb isn't letting gas through?
i'd take the fuel line off the carb and look in the inlet of the carb to see if there is crap in it// then i'd take carb cleaner spray with the plastic sprayer pipe thing and spray inside the inlet to try and dislodge if something is in there
Old 09-05-2010, 04:57 PM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
1406 is a pretty easy carb to take apart, you may have something stuck in the needle seats or in the floats, I took mine apart after watching the video from edelbrock and it was a piece of cake, I had trash from the tank get into the carb....took it all apart, blew air through it and it was good as new.
Smitty
71 C10 283/3SPD Full Resto
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me https://67-72chevytrucks.com/vboard/...d.php?t=841215
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 09-05-2010, 05:12 PM   #4
AustinScott
AustinScott's Avatar
Smitty
the 1406 is pretty easy to take apart, I have had mine apart 3 times now and its pretty simple.
AustinScott is offline   Reply With Quote
Old 09-05-2010, 05:41 PM   #5
guyryan100
guyryan100's Avatar
are you basically taking the top part off the carb? Assume a new gasket is easy to come by. Will I know what I'm looking for when I get it open?
Old 09-05-2010, 08:47 PM   #6
71meangreenc10
See if you can google the video and watch it, the top comes right off and its a snap, most part shops carry the rebuild kit for a 1406 on the shelves. You'll see if there is any problems once the top is off.
Smitty
71 C30 Wrecker
Old 09-05-2010, 09:28 PM   #7
guyryan100
guyryan100's Avatar
Well, that was easy!
I found the video on YouTube:
In the video he was able to re-use his gasket so I figured I'd give it a shot, which worked out okay - no new gasket needed.
There's some other Edelbrock install videos there too, I learned a couple of things about adjusting/setting it up, very helpful info.
Anyway once I got it open I found that the valves that allow the gas flow (operated by the floats) were stuck and just needed a good wiggle to break lose. Amazing how sticky gas-related things get.
Also found it interesting that the floats, which are brass, have some green corosion on teh bottom, and that there was puddle of very green gas in the bottom of hte carb (think Listerine color). My luck, the neighbor's cat probably climbed up there and peed in my carb while I had the air cleaner off. So anyway I got those valves loosened up, soaked up the gas/pee with a paper towel and reassembled the carb, all in about 20 minutes round trip.
Truck running fantastic now.
Thanks guys for the pointer.
Old 09-05-2010, 09:29 PM   #8
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
I have had the 500cfm and 600 cfm, autozone stocked the 600 rebuild kit but didnt stock the 500 but they ordered it overnite, there pretty easy to rebuild lol im doing my 2nd one now (600 cfm man. choke)
John
1999 Toyota Tacoma 4x4
Old 09-05-2010, 09:44 PM   #9
71meangreenc10
Good stuff man, told ya it was easy...I am not a carb person, but even I can fix a 1406....
Smitty
71 C30 Wrecker
1406, edlebrock
