Old 09-05-2010, 01:35 PM   #1
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
Still issues with the lines
Well, took everyones advice and just made my own body mount spacers out of 1/4 inch stock. Got the passenger side door opening nice and good, but the driver's side just won't come in. No matter how much I shim under the #2 position, the door opening won't open up enough to get the windshield frame far enough forward. The top of the vent window is hitting the top of the w/s frame. Guess I'm going to have to make braces to go from the roll bar to the windshield frame to push it out far enough.
I'm thinking about tieing them into the visor mounts, but wondered if anyone else had tried another way? The other thing I thought was to tie them into the top mount bolt on the w/s frame.
Let me know what else you guys think. Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 09-05-2010, 03:17 PM   #2
red71cheyenne
Back in the sticks
Re: Still issues with the lines
Here's a couple of pics of what I'm talking about:
Drivers side:
2011 K1500 Suburban
2014 K1500 Pickup
Old 09-05-2010, 03:17 PM   #3
red71cheyenne
Back in the sticks
Passenger side:
2011 K1500 Suburban
2014 K1500 Pickup
Old 09-05-2010, 07:30 PM   #4
pound41
I am going to but have not yet made braces off the roll bar to the sunvisor. I saw a new jeep and its cage was made like that. I thought of making them adjustable so when I went to remove the to etc i could have them out of the way.
pound41 is offline   Reply With Quote
Old 09-05-2010, 09:07 PM   #5
red71cheyenne
Back in the sticks
I'm thinking the same thing. I went to Lowe's and picked up some 1/2 inch bolts and 3/4 inch pipe to make the adjustable portion. I'll post some more pics up once I get the windshield side brackets bent up out of 1/8 inch stock.
2011 K1500 Suburban
2014 K1500 Pickup
Old 09-05-2010, 09:13 PM   #6
PHAT TONY
PHAT TONY's Avatar
Shims under #2 won't help that gap I don't believe as the door is hung from #1(a-pillar).
If the rocker gap and rear door gap are good, measure to see if the left side is back a bit at the top corner.
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 09-06-2010, 10:27 AM   #7
red71cheyenne
Back in the sticks
I thought number 2 was where you had to adjust that gap. Not real sure as everything I've tried has failed. Shimming number one just moves the w/s closer, so thats not working. Not shimming it to mach the passenger side makes it look like its lopsided. Once I get my brackets bent up today, I'll post pics after I have it installed. I'll leave the body mounts loose to see where the floor moves to. PS, the rocker on that side isn't installed yet as I wanted to get the door gaps right before welding it in.
2011 K1500 Suburban
2014 K1500 Pickup
