Old 06-06-2003, 02:55 PM   #1
dubie
dubie's Avatar
WTB V8 clutch linkage
I am swapping my old inline 6 out for anew 350. This small block will be in the I-6 position and I need the V8 Clutch linkage setup from a 4x4 with a manual tranny.
This is what I'm after:
I have installed this setup in my 68. Using the 4X4 stud and Z bar the linkage lines up perfect. Did not have to relocate the frame mount.
Along with the proper screw in type pivot ball
Can anyone help me out with finding this?
Dubie
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 06-06-2003, 04:33 PM   #2
dubie
dubie's Avatar
I'm sure someone out here must have one kickin around?
Old 06-06-2003, 07:56 PM   #3
smonty
Smonty
reply
I have the complete linkage out of a 70 1/2 ton with a 3-speed and 250 inline 6. If any parts out of this are similar to what you need let me know.
72 2WD Blazer
68 SWB Fleetside
67 SWB Stepside
2005 Chevy 1500HD Crewcab
56 Chris Craft Mahogany Runabout
Looking for 36 Chevy 1/2 Ton P/U Project
smonty is offline   Reply With Quote
Old 06-07-2003, 12:09 PM   #4
Slams_58
we have the same linkage out of our 72, but we are in need of one from a 4x4
Slams_58 is offline   Reply With Quote
Old 06-07-2003, 08:12 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I got some misc part's off a 2wd 350 set up let me know!!
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 06-07-2003, 10:04 PM   #6
4t5acp
I think I still have a complete setup from a '70 K10 with a 3 spd behind a 350. I was going to switch it over to an automatic, but don't have all the linkage for that yet.
Romans 10:9-10
4t5acp is offline   Reply With Quote
Old 06-09-2003, 09:24 AM   #7
dubie
dubie's Avatar
TTT, anyone have one from a 4x4 for sale?
Old 06-09-2003, 08:18 PM   #8
JimKshortstep4x4
Talking
Dubie,
After looking at 4x4 setups and two wheel drive setups this is what I have come up with. The two wheel and four wheel drive "z" bars are basically the same. The 4x4 may have a longer tube, but I believe the two wheel drive will work. The arms are welded on in the same location and at the same angles. The frame bracket is in the same location on the two and four wheel drives. What changes on the V-8's is on the two wheel drive the stud is mounted on a plate which positions the stud in line with the frame mount. On the four wheel drive, the screw in stud is in line with the frame mount when screwed into the engine.
I suggest that you get a screw in stud and use your existing "z"
bar for the two wheel drive as it has more than enough length to engage the screw in stud.
Jim
