Replacing Shocks Question
How can you tell if your shocks need replacing or not? I have the inner fenders off my 72 burb and before I put them back on, wanted to replace the shocks if they need it.
Can someone tell me when is the time to replace them? Thanks for the help, Joe |
Re: Replacing Shocks Question
ill give it a go. how do the shocks look, do they fill like they have any damping when you compress them, are they original, rubber inserts blown out, bent, broke, worn out, these are all factors to look at. my answer is yes since is such a cheap part.
Laid Lo
I was always told if you push down with all your weight and release the truck and it bounces up and down more then twice it's time for shocks.
But if you don't know the age on the ones you have and they don't look new, I'd just swap them. One less thing to worry about. Also if you spend the extra for a better shock you won't be disapointed.
Semper Fi, Jeff ![]() '72 C10 - lays frame '07 Sand Rail - ecotec powered '05 2500HD - tows stuff '67 VW Bug - gas saver '01 Jeep TJ - rock crawler Last edited by blime81; 09-06-2010 at 12:44 PM. |
Thanks for the help. Any suggestions on shocks that won't break the bank??
Grandpa in the rustmobile...
hahai replaced mine awhile back...just got cheapos' from parts store
the ones that came off were sprayed black with undercoating by po, when i got em off you pushed em together, and they stayed there lol.... they were ready to come off!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Laid Lo
I've had good luck with KYB and Monroe. They aren't the cheapest but I can't complain. Currently running CPPs shocks up front. Not sure who actually makes them but they seem good and were pretty cheap. Haven't had a lot of miles on them yet though. KYBs on the back.
Semper Fi, Jeff ![]() '72 C10 - lays frame '07 Sand Rail - ecotec powered '05 2500HD - tows stuff '67 VW Bug - gas saver '01 Jeep TJ - rock crawler |
