Closed Thread
Old 09-07-2010, 08:24 PM   #776
Sonicman
Sonicman's Avatar
Re: What did you do to your truck today!
Went to a machine shop to inquire about having my L6 head cleaned up. When I got back to the truck it wouldn't start..... The mechanic came out and gave me a jump. Then I replaced the alternator. What a better place to need a jump than mechanic shop.
Sonicman is offline
Old 09-07-2010, 08:50 PM   #777
Todd Hepler
Rottenwood Garage Member
Todd Hepler's Avatar
Painted my control arms with POR-15.
I think I am still loopy from the fumes!
Todd
Todd Hepler is offline
Old 09-07-2010, 09:24 PM   #778
Hubscrub
Cruzin
Hubscrub's Avatar
picked up the block and crank from the machine shop for the 67
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline
Old 09-07-2010, 10:43 PM   #779
marks1972
marks1972's Avatar
Changed my cam and lifters. Easy job everything went perfect. Nothing went wrong.....NOT. What a pain in the but. If I ever have to do this again I will pay someone to do it.
Mark
1968 C-10 SWB 307/munci 4spd/411possi 1986-1990
1972 Cheyenne-10 LWB 350/TH350
IF SHE WHOULD HAVE KEEPT THE SHIRT ON THEY WOULDNT HAVE BROKEN UP THANKS ADAM SANDLER
U. S. Navy Seabee
"CAN DO", "The difficult we do at once. The impossible may take a little bit longer.","We Build We Fight", "Work Hard Play Hard"
marks1972 is offline
Old 09-07-2010, 10:56 PM   #780
JoeKan
JoeKan's Avatar
Installed a new battery tray and finally got her running.
JoeKan is offline
Old 09-09-2010, 05:17 PM   #781
67Slider
67Slider's Avatar
Took the plunge and ordered the 69 camaro gas tank kit. Got the tank, sending unit, straps, lock ring/o ring and the anti-squeak kit for $194.00. Will relocate the filler to behind the license plate.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline
Old 09-09-2010, 05:31 PM   #782
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Took Tilt Apart To Repair What Other Guy Should Have Fixed..
Started Lowering
Ordered Weather Striping Kit
1971 GMC SHORTY is offline
Old 09-09-2010, 07:27 PM   #783
llowlife
Removed fenders and box for a trip to the body shop as someone frenched in some lights and it has since rusted. Shes going back to factory. Hooked up a TPS to the quadrajet
llowlife is offline
Old 09-09-2010, 07:38 PM   #784
pro1955
pro1955's Avatar
Who did you buy the kit from? I'm looking to do the same.
Truck's just for the fun of it.
pro1955 is offline
Old 09-09-2010, 08:39 PM   #785
Hubscrub
Cruzin
Hubscrub's Avatar
cleaned one window, changed oil in the 97
Proverbs 3:5,6
Hubscrub is offline
Old 09-10-2010, 08:19 AM   #786
Jwill41
Jwill41's Avatar
started cleaning up the burb for the Pickups-n-Panels show tomorrow.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline
Old 09-10-2010, 03:34 PM   #787
tratman2000
tratman2000's Avatar
i done several burnouts and then went to my friends tire shop and got a new set of cooper cobra radial gt 275/60/15 it looks and handles a lot better i dont know why even make other sizes
tratman2000 is offline
Old 09-10-2010, 03:44 PM   #788
bigdogboxers
bigdogboxers's Avatar
get us a picture of those tires i am also looking at that tire size for my 1962 gmc.
bigdogboxers is offline
Old 09-10-2010, 09:40 PM   #789
Hubscrub
Cruzin
Hubscrub's Avatar
got the bearings and rings for the 67
Proverbs 3:5,6
Hubscrub is offline
Old 09-11-2010, 02:27 AM   #790
OhioDan
OhioDan's Avatar
Thumbs up Re: What did you do to your truck today!
Re-installed clutch return spring. Was looking under my truck for something, and saw the spring had come loose from the frame. Slid(? forced) my big fat behind under the truck and put it back on. Thought the clutch pedal felt funny.
LIFE AIN'T EASY WHEN YER FAT AND GREASY!
GMC= Got More Class!
1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started.
OhioDan is offline
Old 09-11-2010, 07:49 AM   #791
Todd Hepler
Got my front cross member painted.
4 a arms and a cross member and I have only used 1/4 quart of por-15. This stuff sure goes a long way!
-Todd
Old 09-11-2010, 08:30 AM   #792
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
yep just be sure to lay a piece of plasic wrap over whats left in the can (like a paint skin) then throw it in the freezer ..or whats left will be like a rock!!!
well I adjusted the drum brakes on the truck cleaned up the points lubed everything under the cap checked the tire presure...and loaded the chain saw!!...Yep its that time of the year again Fire wood season!!!
Hottrucks is offline
Old 09-11-2010, 02:27 PM   #793
MONTE
MONTE's Avatar
Worked on some gauges.
MONTE is offline
Old 09-11-2010, 03:42 PM   #794
Hottrucks
Hottrucks's Avatar
hey on my wood detail today I scored an Apache pop up camper...the shell is good with all the hardware so I'm going to look into new canvas...if not it may get a chopped down tonue cover and I'll use it to haul my camping stuff..either way its a win
Old 09-11-2010, 03:49 PM   #795
88fordf150
88fordf150's Avatar
Mounted my front wheels and painted and installed my Big Block perches.
Brad handshoe
88fordf150 is offline
Old 09-11-2010, 04:13 PM   #796
Shane
Shane's Avatar
re-installed the transmission ... yay! no leaks!
Shane is offline
Old 09-11-2010, 05:42 PM   #797
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re-installed a steering stabilizer I had just cleaned up & re-painted. While I had the creeper out, I changed oil & filter and greased all the zerks.
Nothing exciting, but it needed done....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now
Old 09-11-2010, 07:04 PM   #798
Hubscrub
Cruzin
Hubscrub's Avatar
built the lower end of my motor for the 67
Proverbs 3:5,6
Hubscrub is offline
Old 09-11-2010, 09:08 PM   #799
Rob H.
Rob H.'s Avatar
Started redoing the brake system on the 72. Then went and took a look at a 69 for parts, yes it followed me home tonight.
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline
Old 09-11-2010, 09:16 PM   #800
Street Lethal '72
Street Lethal '72's Avatar
Pulled the bed, and the PO's in-bed gas tank off the '72.
Street Lethal '72 is offline
Closed Thread
